DL 1000 starting issue. - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
  • 1 Post By bwringer
  • 1 Post By larolco
post #1 of 9 Old 05-06-2018, 09:56 PM Thread Starter
Got my DL out of winter storage. Won't start. It has fuel pressure to throttle bodies, spark is good, no FI codes. Starts with ether. I thought of tip over sensor but it hasn't fallen over. Any ideas on testing injectors without removing them? Any ideas are welcome.
Sent from my SM-G920W8 using Tapatalk
kin0689 is offline
post #2 of 9 Old 05-06-2018, 10:29 PM
Kin, look up "Noid Lights" in at tool suppliers like Snap-on, MAC, Cornwell, etc. These are small sockets with terminals that mate to the injector harnesses. You unplug an injector, plug in a noid light, and crank the engine looking for a pulsating flash. The flash indicates you have a key-on power to the injectors from the EGI relay, and a pulsating ground in the ECU.
IF you have compression, and IF you have spark, and IF the spark plugs arent fouled,and IF you have air, and IF you have proper fuel pressure(measured), and If the fuel itself is good, and IF you have injection pulse, and IF the injector is working...IT SHOULD RUN.
Injection pulse and ground can be tested with an automotive 12VDC testlamp, the noid light makes testing much easier.
MAZ4ME is offline
post #3 of 9 Old 05-07-2018, 05:45 AM
Rolex's Avatar
If it starts with ether it is a fuel problem not a electrical one so forget any safety switches.
Are you sure your fuel pump primes each time you turn on the ignition ?
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #4 of 9 Old 05-07-2018, 07:05 AM
Pull one of the injectors out and crank the engine over. If it sprays fuel, you have fuel pressure. Sounds like you are not getting fuel to the engine....
realshelby is offline
post #5 of 9 Old 05-08-2018, 10:32 PM
bwringer's Avatar
What year DL1000?
I mean, that doesn't make a hell of a lot of difference to diagnosing this, but it makes some difference in the odds of various issues. Older bike, certain things are more likely.
Here's my wild-ass probably low percentage guess: is the bike wearing a failed Power Commander? Make sure the Power Commander's black ground wire is hooked up to the negative terminal of the battery. If that doesn't help, take the Power Commander out of the equation completely. Unplug it from the injector connectors (you can usually juuuuuuuuuust barely reach these by reaching through the frame), inspect the connections for corrosion, then plug the bike's injector connectors together and see whatchya got.
And please, please, please shitcan that starting fluid. That crap is dangerous, damages your engine, and does not tell you anything useful. It has no place in anyone's garage.
pvwheeler likes this.
bwringer is offline
post #6 of 9 Old 05-08-2018, 10:34 PM
bwringer's Avatar
Easier said than done, you know... Lots of parts to excavate.
It's easier to pull a spark plug and take a look. If it's wet and smells like gas, well, the injectors are injecting. And normally if an engine isn't starting and the injectors are working, you'll smell gas and the engine will be flooded. Might even need to leave the plugs out overnight to let the excess gas evaporate.
bwringer is offline
post #7 of 9 Old 05-09-2018, 12:57 AM
DId you treat the gas before winter storage, and how long was it stored?
post #8 of 9 Old 05-09-2018, 04:56 AM
Griff2's Avatar
Battery voltage ok ?
Griff2 is offline
post #9 of 9 Old 05-09-2018, 11:51 AM
larolco's Avatar
Probably you've already done this, but crank the starter with the throttle wide open.
It's not likely that anything has gone terribly wrong over the winter other than your gas got old. Or a rat built a nest out of your wiring.
Spec likes this.
DRZ400SK17
larolco is offline
