Which coil wire is the negative side? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By Rolex
post #1 of 8 Old 04-28-2018, 01:41 PM Thread Starter
pvwheeler's Avatar
Question Which coil wire is the negative side?
Trying another tack to find a signal for my audiovox cruise on my V2 .
Not having any luck with the brown/black (tach feed) wire.
Would the negative wire be the common colour between all four coils? Or the one which is a different colour between coils?
Thanks for any help!
2015 Wee2 EXP "Arya"
2002 DR650 SM "Tormund"
2014 CB500x (wifes)
2018 XT 250 (wifes)
pvwheeler is offline
post #2 of 8 Old 04-28-2018, 04:27 PM
Do NOT mess with the ignition coils!!!
They fire when a ground is added, not when power is given to them.
Anything you might tap into that circuit might be a big problem......
realshelby is offline
post #3 of 8 Old 04-28-2018, 05:35 PM Thread Starter
pvwheeler's Avatar
Just thinking that is how the audiovox cruise is installed on a versys and connnie 14. I cant seem to get a tach signal from the brown/ black wire....
2014 CB500x (wifes)
2018 XT 250 (wifes)
post #4 of 8 Old 04-28-2018, 11:06 PM
Rolex's Avatar
When I fitted my MC Cruise I used the brown wire with black stripe up near the radiator cap.
It is in a plug with the pink / white speed wire.
pink/white is on the lower row in the left corner then there is a green/yellow then the brown/black taco wire that I used, is this the same brown black you used ?
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #5 of 8 Old 04-29-2018, 08:13 AM Thread Starter
pvwheeler's Avatar
Thanks for the reply Rolex.
Yes that is where I connected mine as well. I even bought a new unit to rule out a bad computer (unless I got 2 in a row) .
The wire has continuity according to my ohm meter and I have tried connecting without the resistor just in case. Maybe I should try and find a new connector and replace the wire feeding the servo just to try....Everything else tests perfectly except I have no tach signal. (yes the engine is running and the cruise is turned on lol ;^) )
Thanks for your help!
Steve
2014 CB500x (wifes)
2018 XT 250 (wifes)
post #6 of 8 Old 04-29-2018, 02:20 PM
Rolex's Avatar
I would think if the taco on your bike is working you have problem with your CC or the install ?
pvwheeler likes this.
2014 V2, Snoopy
Rolex is offline
post #7 of 8 Old 04-29-2018, 08:10 PM Thread Starter
pvwheeler's Avatar
Dont know, I have a LOT of hours into this over the winter,and I'm going to try 1 or 2 more things then give up.Maybe I can get it working on my next bike
2014 CB500x (wifes)
2018 XT 250 (wifes)
post #8 of 8 Old 05-05-2018, 09:07 PM Thread Starter
pvwheeler's Avatar
Talking
Well I got it working using the white blue wire of the top right coil.
I have no idea why it wouldnt work using the tach feed,and at this point I dont care
I also didnt use the speed sensor wire. Its not needed
Extremely happy its finally working!!
2014 CB500x (wifes)
2018 XT 250 (wifes)
