Heated Grip Connection - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 06-12-2009, 08:39 AM Thread Starter
Deckard's Avatar
After installing a set of Oxford heated grips with the direct to battery connection, I got a connector from Eastern Beaver and now have a "switched" connection - good idea for someone like me who WILL eventually, forget to turn them off. While making the change, I found TWO (2) unused connections - the wrong one first of course. Fortunately, Suzuki must have made things idiot proof and the "other" connection did not fit Jim's wiring harness. Just curious as to what the other unused connector is for??
Second question - when I first start the bike, if I turn the grip heaters on immediately, the blue light on the (digital) control flashes and it shuts itself down. I assume this is due to lack of power - once the bike has run for a minute of two, the heaters work fine. Is this a sign the battery is going (OEM on a 2005)???
My apologies if this has been dealt with before.
Deckard is offline
post #2 of 7 Old 06-12-2009, 08:52 AM
Dread7's Avatar
When you installed the fuse box, the hot is directly connected to the battery and the "switch" is connected to a relay right?
Formerly clovett but changed to my gaming name
2004 DL650 1998 DR650 1994 CB1000 1992 DR350
2004 Z400 1965 Norton 650 1984 Honda XL200
1975 Suzuki RM125 1972 Yamaha 100 enduro
1971 Honda CT90 1968 Honda Z50A
Dread7 is offline
post #3 of 7 Old 06-12-2009, 09:28 AM Thread Starter
Deckard's Avatar
No fuse box - initially, I had the supplied wire (with inline fuse) direct to the battery. Now I have used the Eastern Beaver adapter cable that allows one to plug into the Suzuki connector. In both cases the symptoms are the same.
Deckard is offline
post #4 of 7 Old 06-12-2009, 10:09 AM
Dread7's Avatar
If you wired it direct to the battery and it doesn't work correctly I would think your heated grips have a problem. Hooking directly to the battery should make it work. If it doesn't you can stop right there and troubleshoot.
Dread7 is offline
post #5 of 7 Old 06-12-2009, 10:38 AM
Oxfords shut down when available voltage is low. It could be a battery problem or just that the engine has to be running over idle to get things high enough.
post #6 of 7 Old 06-17-2009, 02:48 PM Thread Starter
Deckard's Avatar
Thanks for the info gentlemen!
Deckard is offline
post #7 of 7 Old 06-17-2009, 04:27 PM
ezrdr55's Avatar
I had to remove the connector from Eastern Beaver and wire direct to the battery. The voltage at the connector from Eastern Beaver was 1 volt lower than at the battery and the heated grip controller would shut off.
EZ-RDR55
The opinions expressed herein are mine, and do not represent that of any other humanoid past, present or future on this or any other planet.
'95 H-D FXDWG
'06 Honda CRF250X
'04 KTM 450EXC
'97 Honda XR-600R (Sold)
'04 K1200LT (Sold)
'07 K1200GT (Sold)
'09 Wee-Strom DL-650ABS
'14 WR250R
ezrdr55 is offline
