Weird vibrating noise from engine - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 06-08-2009, 02:48 PM Thread Starter
Hey Guys,
I just recently bought my first every bike, a 2008 DL1000, and I am loving it. This weekend I did the first maintenance at 1000km. With that, I changed the oil and filter and replaced it with the Suzuki dino 10W40 and a Suzuki filter. I took it out for a spin yesterday and noticed a strange vibrating noise coming from the motor. When I got it home, I put my ear down by the motor a give it a few revs. It definitely sounds like it is coming from the block (or that area). It occurs when in gear or not and through a wide range of RPM.
Does anyone have any idea what might be causing this? Or is it something normal? Should I have used a different oil &/or filter, different viscosity maybe. Any help you can provide me with will be greatly appreciated as I am new to the game... This is also my first post. Thanks.
dbillard is offline
post #2 of 4 Old 06-08-2009, 04:48 PM
kenneth_moore's Avatar
The oil you used is fine. Unless you grossly under or over filled the crankcase, you're probably hearing normal noises. It's barely broken-in, it will run smoother and quieter as time goes by.
Go hakafugu yourself.
kenneth_moore is offline
post #3 of 4 Old 06-09-2009, 09:32 AM Thread Starter
Good to know Kenneth and thanks. Its my first bike (ever) so I'm not sure what is normal and what isn't.
dbillard is offline
post #4 of 4 Old 06-11-2009, 08:43 PM
Mine gets noises that seem to come and go. I am being honest when I say that wearing earplugs will increase your enjoyment of the bike.
That said, just check for loose bolts.
2012 CBR250R Tricolor
tylerSC is offline
