Valve shim source - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 03-20-2018, 08:56 AM Thread Starter
Valve shim source
I’m planning to do a valve clearance check soon. I see on the parts fiche that the shims are sold in .05mm increments, but I think I have read of people using .025 increment shims. Where would I find these if they do indeed exist? I’m weary of aftermarket parts - maybe there is another oe using .025mm increments and the same diameter shim as my 06 dl650? Thanks
Om Nom Strom is offline
post #2 of 5 Old 03-20-2018, 09:45 AM
blaustrom's Avatar
You can find them here. Make sure you key in the correct model/ year info
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
post #3 of 5 Old 03-20-2018, 01:14 PM Thread Starter
Thanks. Have you used these pro x shims long term? If I have to buy shims I want oem quality. It appears that Honda gl1800 gold wing uses the same diameter shims (along with dozens of others I’m sure) and offer oem shims in the .025mm increments. I would feel better about the quality control there.
post #4 of 5 Old 03-20-2018, 01:24 PM
If you are worried about quality control, simply measure each shim with a micrometer. These things really don't wear, so there isn't much "quality" involved beyond correct dimensions. I am pretty sure Honda, or Suzuki, don't make their shims. There is likely one or two companies that make 90%+ of them for everyone.
Many of us have used the Hot Cams branded shims. You can buy the kit, or like many just buy a few sizes of the refill packs. That is all I ever needed. These are readily available, just shop for a good deal.
realshelby is offline
post #5 of 5 Old 03-20-2018, 02:53 PM
Stalky Tracker's Avatar
Like RealShelby said, I went with the Hot Cams refill kit. If my memory is correct, it was HCSHIM04 7.48mm for a K6 Wee.
2006 Suzuki V-Strom DL650K
1986 Honda Shadow VT700C
1974 Suzuki TM-250
1965 Suzuki 80
Stalky Tracker is offline
