clock problem - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 19 Old 04-06-2006, 08:04 AM Thread Starter
clock problem
I had a mishap with my Wee that caused me to have to replace the front end. I got it all back together, and the speedo, tach and display is working, the clock is showing, but I can't set the clock. When you hold down the two buttons, it never flashes to change. I checked all the fuses, and disconnected the battery to try to reset, but no luck.
Any suggestions or help would be much appreciated.
Thanks in advance!
stromny is offline
post #2 of 19 Old 04-06-2006, 09:23 AM
Re: clock problem
Thanks in advance!
Turn the ignition on, and then try it!
post #3 of 19 Old 04-06-2006, 09:35 AM Thread Starter
Tried the ignition on... still a no.
stromny is offline
post #4 of 19 Old 04-06-2006, 10:31 AM
Press and hold the left "select" button first, then press the "adj" button, it should work...oh yeah, turn ignition on too.
nighthawk is offline
post #5 of 19 Old 04-06-2006, 11:17 AM
Ignition on, be in neutral, keep holding the buttons down for at least five seconds, try it with the engine running.
post #6 of 19 Old 04-06-2006, 11:26 AM
Redbeard's Avatar
You have to have the ign. ON and the bike in Neutral, then you have to press both the "SEL" and the "ADJ" buttons at the same time.
On my bike, it takes several attempts to get both buttons pressed at the same time - even though I think I did it correctly.
Take care,
Bob S.
DL1000K6 - Gray
Only motorcycle riders understand why dogs ride with their heads out the window.
Redbeard is offline
post #7 of 19 Old 04-06-2006, 11:45 AM
Send a message via Yahoo to SmkyMtnVStrom
On mine a DL650 K5 the engine has to be running. Hope it helps.
'05 Blue V-Strom 650
GO VOLS!!!
SmkyMtnVStrom is offline
post #8 of 19 Old 04-06-2006, 01:18 PM
Same here
Blue DL650K5
lajaro is offline
post #9 of 19 Old 04-06-2006, 04:07 PM Thread Starter
Thats it!!! Left button first, then right button with ignition on.
You think I would have done that by accident,
the number of times I've hit the damn thing.
Thanks for the help!
stromny is offline
post #10 of 19 Old 04-06-2006, 08:52 PM
Stromny, dare I ask what the mishap was ?
05 / 650 in blue
88 / KDX 200 in green
81/82 DT 175 Yamahussies
78/ GT 750 water pumper
75/Suzuki 125 RV
water warrior is offline
