Tutoro Auto Chain Oiler: Single or Double Nozzle Kit? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 74Likes
post #1 of 122 Old 02-12-2018, 07:55 PM Thread Starter
lmike6453's Avatar
Question Tutoro Auto Chain Oiler: Single or Double Nozzle Kit?
I just cleaned and lubed my chain for the first time as a new rider after a ride on wet roads and it is such a mess, plus time consuming to do regularly!
I've been reading rave reviews about the Tutoro Auto Chain Oiler system and am excited that it won't break the bank too much compared to it's farkle worth
Should I get the single or double nozzle setup for the Wee2 (2014 Vstrom 650 Adventure)?
I'd like to get single for simpler setup, less oil fling, and save money. But want to adequately lube the chain in temperatures ranging 35F <--> 95F
Does the standard kit provide everything needed for install if I go single nozzle? Or just go deluxe?
https://www.tutorochainoiler.com/pro...r-standard-kit
lmike6453 is offline
post #2 of 122 Old 02-12-2018, 09:33 PM
Order from Rick "Adventuretech" and the kit he sells has "both" of the nozzles kits, the single is all that is needed and what I use. I have used mine now for about 6,000 miles, including some gnarly and nasty goo mud sand silt off road in New Mexico. It works simply amazing, you just need to adjust the flow rate depending on the temps out. I have mine at just over half turn out when above 60 degrees, and will go to 3/4 turn out when below that. I have less mess than I ever had with spray lubes, and my ENTIRE chain gets coated with the single nozzle set up. I can send you pics of my install if you like, that and I am pretty familiar with this system. But......give Rick a call and he will hook you up, plus he has free tech support if needed too. Get the deluxe kit as it is the best deal going, that is what I have.
Well damn......looks like Rick isn't a dealer for them anymore.
Rides2Work likes this.
post #3 of 122 Old 02-12-2018, 09:36 PM
drmonbowen's Avatar
I'd LOVE to see photos, please.
drmonbowen is offline
post #4 of 122 Old 02-12-2018, 09:39 PM
Highwayman2016's Avatar
I think I got the deluxe kit, can’t remember. I guess I did because it had both nozzles. I just did the single.
2014 650 Strom
Highwayman2016 is offline
post #5 of 122 Old 02-12-2018, 09:45 PM
Your flow rate seems a bit much highwayman, I don't have fling like that.
Quixote1 and eagleeye like this.
post #6 of 122 Old 02-12-2018, 09:58 PM
Lets see if this works........not the best up close or large pics, let me see if I can do better, or I am happy to email or text the pics.
File Type: jpg A54B63A1-7FC5-4F3E-B63E-7927146AC240.jpg (20.1 KB, 156 views)
File Type: jpg 094E74C6-1D41-4FFC-8D97-64399FAB6531.jpg (12.5 KB, 146 views)
post #7 of 122 Old 02-12-2018, 11:15 PM
Cal Scott's Avatar
Anyone know if there is a source for Tutoro in the US now? Looking on their website I don't see any US distributors (stockists as they refer to them) listed.
Cal Scott is offline
post #8 of 122 Old 02-13-2018, 12:01 AM
1/4 turn
2014 650 Strom
post #9 of 122 Old 02-13-2018, 12:31 AM
larolco's Avatar
Ordered the deluxe kit from England on Ebay.
Not sure if it's going on the DRZ or the Vee yet. Thinking DRZ just cuz it's newish and spokes are a pain to clean of chain lube. And I plan to ride the snot out of the thing this year now that I've got it set up with an oversized tank, windshield, volt-meter and heated gear outlet. Flatlander skid plate arriving soon. The Vee shall slide into a well deserved retirement from everyday use over the next year and become more of a touring/winter commuter. That's the plan anyway, if the DRZ gets the job done for most of the year.
I wish I'd done this a decade ago with the Vee. Now it's just, like, myeh. The rear is caked in fling and will stay that way forever. Unless I really like the Tutoro and decide the Vee needs one too.
I'll likely use the double nozzle since I ride a lot in the rain and salt. I've always been conscious of spraying both sides of the chain; otherwise the rust sets in during the winter months.
DRZ400SK17
larolco is offline
post #10 of 122 Old 02-13-2018, 11:38 AM
Ebay is now the US source, per Rick at Adventuretech.
