turned the key and NOTHING....... - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 05-26-2009, 07:48 PM Thread Starter
webbhead2's Avatar
Send a message via Yahoo to webbhead2 Send a message via Skype™ to webbhead2
i went out today to start my '05 dl 1000... when i turn the key... nothing happend... no lights no horn no alarm... nothing.
tried to jump it... (i know this is bad for the battery) and still nothing doing..
took the battery out. load tested it... BAD... volt tested it... DEAD... so i got a new battery...
came home, put it in, turned the key..... NOTHING.... like before.
any ideas, suggestions... HELP???
i ride daily, rain, shine, hot, cold. people think im nuts... but at this point its my only transportation...
thanks in advance...
its not about [COLOR="Red"]WHAT[/COLOR] you ride, but [COLOR="red"]IF[/COLOR] you ride
webbhead2 is offline
post #2 of 7 Old 05-26-2009, 08:04 PM
Did you check the fuses?
DL1000K8
So what is it, am I a smart*** or a dumb***? Maybe I'm just an ***hole.
10guy is offline
post #3 of 7 Old 05-26-2009, 08:19 PM
Kill switch?
dsm_rally is offline
post #4 of 7 Old 05-26-2009, 08:50 PM
Bamaboy's Avatar
Did you put it in N and pull in the clutch? I know stupid question but I have forgotten things like that before.
2004 Silver V-Strom 1000 & 1994 Yamaha XT600
Farkles? Sargent Seat, Genmar risers, K&N filter, cramp buster, heated grips, PCIII, Givi Engine Guards, Givi Hard Bags 52 liter and two 45 liter, Givi shield with spacers for buffeting.
Bamaboy is offline
post #5 of 7 Old 05-26-2009, 10:35 PM
Check the fuses as said above.
This happened to me about a month ago, I had assumed it was the battery as it was a couple of years old and i hadn't ridden it for about 5 days. I thought my son turned the alarm on with the remote.
Anyway, I went and got the battery checked before buying a new one, it had 12+volts and held a 12+volts under load. So it wasn't the battery.....
Could have saved a trip if I looked at my fuses, one of the 30amp fuses had blown, 2 sec fix.
choccoloco is offline
post #6 of 7 Old 05-27-2009, 01:02 AM Thread Starter
webbhead2's Avatar
Talking GOT IT!!
yeah you know im an old harley guy and didnt know for sure if there was a MAIN fuse between all the other fuses... i checked the fuses first and found them all to be good. but thought later that there MUST be a main fuse somewhere... so i looked in the owners manual, and there it was... NOT by the other fuses... WHY??
anyway... its fixed thanks a bunch for your input. i know i can always count on my fellow troopers.....
post #7 of 7 Old 05-27-2009, 01:53 AM
Your welcome
DL1000K8
10guy is offline
