Front Brakes Squeaking - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 9 Old 03-31-2006, 02:53 PM
zady
My bike is an '04 with only around 1350 miles on it, but my front brakes are squeaking when I come to a stop. It's not TOO bad, but I just feel like it shouldn't be happening.
I did check the wear on the pads, and according to my inspection, they're completely fine.
Could it just be some brake dust or something minor like that?
Any suggestions?
Thanks.
post #2 of 9 Old 03-31-2006, 04:02 PM
Zady,
It could very easily be brake dust. Try cleaning the rotor and caliper area and see if that makes a difference. In some cases the pads can get glazed from heavy use, which can cause squeaking. To check for glazing, you would need to remove the caliper and look at the pads. A fine sandpaper can be used to slightly rough up the pad surface if needed. It all depends on what you are comfortable performing on the bike. These two things are very easy, but if you were experiencing other symptoms, like vibration when you brake, then there would be more to it then dust or glazing. Try the cleaning first and go from there. A high pressure water hose often will do the trick.
stlrmike is offline
post #3 of 9 Old 03-31-2006, 04:30 PM
Zady, here is another approach but I might get flamed for it. Years ago on dirt bikes when the brakes got munged up with mud and yuk we would lightly sandblast the linings and they came out like new. Ride On.
05 / 650 in blue
88 / KDX 200 in green
81/82 DT 175 Yamahussies
78/ GT 750 water pumper
75/Suzuki 125 RV
water warrior is offline
post #4 of 9 Old 03-31-2006, 10:17 PM
A guy I used to work with(key words"used to"), would soak brake pads in WD40 to get them to stop squealing.
P.S. DON'T DO THIS.
spongebob218 is offline
post #5 of 9 Old 03-31-2006, 10:57 PM
WD40 ??? Not my idea of a penny tech solution to anything that requires friction to save your life. Like adding gas to a fire to make it go out. WD40 may be a good cleaner BUT !
05 / 650 in blue
75/Suzuki 125 RV
post #6 of 9 Old 03-31-2006, 11:29 PM
zady
Originally Posted by stlrmike
Zady,
stlrmike,
No vibration felt. Just the squealing, and I do feel comfortable removing the caliper and looking at the pads, so I'll try that first (using the sandpaper), and see what happens. Thanks for the advice.
P.S. How exactly do you clean the rotor? Any special solvent, or is it just wiping with a damp sponge?
For Water Warrior:
Thanks for the tip, but I think I will first try the more subtle approach. :wink:
post #7 of 9 Old 04-01-2006, 12:04 AM
Subtle is good. Wrench on. Wrench well.
05 / 650 in blue
75/Suzuki 125 RV
post #8 of 9 Old 04-01-2006, 08:27 AM
Zady,
Shouldn't need any solvents. I would just use the water hose and a mild cleaner (simple green, car wash solution, etc.). You could use brake cleaner, but be careful spraying it around painted surfaces. If you do use brake cleaner try spraying it on a rag and wiping down the rotors rather than spraying it directly on the bike.
stlrmike is offline
post #9 of 9 Old 04-02-2006, 09:51 PM
steve tech
They do!
Just ride it!
