metal in the oil... - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 4Likes
post #1 of 13 Old 12-20-2017, 03:18 PM Thread Starter
Also Ran's Avatar
metal in the oil...
So I've started pulling apart the DL1000 2003 and draining the fluids so I can get the clutch basket done. After pouring the oil out of the catch into a container I inspected the left over residue. Now I know you can get a bit of metallic shimmer but this was more than that. There were several fragments/shavings in the bottom of the catch. Smaller than a finger nail clipping but still big enough to get that Oh Owe feeling. I'll be pulling the cover over the week end and get a better look but has anyone else with the chudder experienced this? It was vibrating pretty bad. Now so am I.
"There's a Grey blur and a Green blur. I try to stay on the grey one." Joey Dunlop
Also Ran is offline
post #2 of 13 Old 12-20-2017, 03:34 PM
Is this the first time you have drained them all and are they steel bits? I know its a sick feeling from ten years of drag racing but sometimes not near as bad when you get in but sometimes big $$$$.Good luck and Merry Christmas.
Old Time Rider is offline
post #3 of 13 Old 12-20-2017, 03:35 PM
It's possible that the fragments came from the clutch assembly. That's why it chudders, more or less. It's unlikely that it's other moving parts though it does happen. Let us know what you find in there.
Old Time Rider likes this.
bobbyvstrom is offline
post #4 of 13 Old 12-20-2017, 03:45 PM
Had a all new 1978 GS1000 Suzuki .The chain drive fast one like V&H set new pro stock records with. Blew a clutch basket at red line and a chunk went through the rear of the motor in front of the spinning rear tire. Hot oil ride and luck with me as went in grass and did not go over. Blew four more in two years! Some looked like a bomb had went off.So sick to open up each time.Machine shop made a 1100 basket fit after sold to a friend and it saw lots more strip use with that 1100 basket.
post #5 of 13 Old 12-20-2017, 05:01 PM
Is this the catch under the rectangular oil screen, under the clutch basket?
Can't say for sure of course, but if the engine cover there has never been pulled and the screen never replaced/cleaned, it might just be residu from the manufacturing process. That's what the screen is for in the first place.
Quick test: are the bits steel or aluminium? You can tell with a magnet. Aluminium = probably good news, steel = probably bad news.
Big B likes this.
BackPacker is offline
post #6 of 13 Old 12-20-2017, 05:58 PM Thread Starter
Also Ran's Avatar
It was the oil catch I put under the bike to drain the oil. I'll be pulling the cover tomorrow and will have a much better idea. I do what our family call "awfullizing" assuming the worst so to speak.....
Pretty sure they were aluminium but haven't taken a magnet to them yet. Once the cover is off I'll have a better idea as to how tools or crack a beer. Either way in for a penny in for a pound. Fingers are crossed.
Also Ran is offline
post #7 of 13 Old 12-20-2017, 07:18 PM
do you know if the clutch basket was shimmed?if yes it might be the welding pieces coming apart.been there,done that.
cenksinan is offline
post #8 of 13 Old 12-21-2017, 08:35 AM Thread Starter
Also Ran's Avatar
Well boy is my face red! So like an idiot I left the drained oil sitting under the bike. When I was removing the crash bar I noticed the PO had cross threaded one of the bolts (most of you will already guess the the rest) Not wanting to forget I immediately got the tap and dye set and gently retapped the threads. I'm thinking the particles dropped from the back side of the hole onto the cover and slid into the oil. Duh. Talking to the wife about it and the "brain light" came on. I'll check thoroughly today when I pull the cover but it seems like the issue was well, me AGAIN. Cheers and thanks anyway.
Also Ran is offline
post #9 of 13 Old 12-21-2017, 09:32 AM
D.T.'s Avatar
Went through this on my SV when I got it. Aluminum from the clutch made the oil look metallic. Fingers from the clutch basket, plates rattling back and fourth wear the AL down.
D.T. is offline
post #10 of 13 Old 12-21-2017, 07:59 PM
Bogfarth's Avatar
This is why you buy a Ducati. Well, this and the bike can play Jingle Bells as you bomb down the road (most Ducs have a dry clutch.)
Being slow doesn't make a boring bike. I had a R1 which I thought was boring. Boring is a bike that doesn't speak to you. If you like what your bike is saying let it's voice take you to far flung places. - Vertical C
Bogfarth is offline
