Has Anyone Used This Lift for their 650? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 11 Old 03-27-2006, 11:29 PM
zady
Here is a picture of the lift I own.
I used this when I owned my KLR650 with no problem, but the underside of that bike was pretty tidy. The DL650 underside makes me hesitate to put a lift under it (more specifically, because of the radiator and exhaust pipes).
Does anyone use this for their Wee, and if so, is there any special way of lifting the bike to prevent damage?
Of course, I probably will just try it out...slowly...but I thought I'd see if anyone has experience with it.
Thanks.
post #2 of 11 Old 03-28-2006, 06:27 AM
I've seen pictures and posts on adapters to use with a lift. Try Search for lift adapters.
Michael P. is offline
post #3 of 11 Old 03-28-2006, 12:30 PM
Personally, I'd be nervous about using any of these types of lifts without a bike that has frame rails underneat the bike. IOW, these work great on Harleys.
- Mark
markjenn is offline
post #4 of 11 Old 03-29-2006, 12:52 AM
This type of jack will not work with the exhaust system under the motor.
The screw type are better with adpater pins to get around the ehaust. That type of jack works best on Harleys, Gold Wings, where there is a frame to jack up on.
scooter is offline
post #5 of 11 Old 03-29-2006, 02:30 AM
zady
You guys are confirming my suspicions.
Hmmm, I guess I'll just have to add a centerstand to my list of "needs". :P
post #6 of 11 Old 03-29-2006, 05:05 AM
I would not own a bike without a center stand. And I get to take it with me on the road just in case. Ride On, Ride Safe.
05 / 650 in blue
88 / KDX 200 in green
81/82 DT 175 Yamahussies
78/ GT 750 water pumper
75/Suzuki 125 RV
water warrior is offline
post #7 of 11 Old 03-29-2006, 01:47 PM
Just to make your decision harder..... I have one of those and it works fine ***if you have a skid plate****
I have the SW-Motech guards and plate and it perches on there just fine.
--Kevin
2005 DL 650 K5
ex - 2002 KLR 650
ex - 1981 IT 250 Yam (wish I still had it!)
ex - 1979 GS 750
ex - 1966 BSA 650 Lightning
ex - 1978 DT 400 Yam
ex - 1974 MX 125 Yam
ktisdall is offline
post #8 of 11 Old 03-29-2006, 06:32 PM
Send a message via Skype™ to torqueman
That is interesting. I have the SW Mototech guards and plate too and like them just fine but I would not have believed the plate was heavy enough to lift the bike like that.
torqueman is offline
post #9 of 11 Old 03-30-2006, 01:01 PM
David Harry
I made a simple blocking plate for my DL1000 that works quite well with my Harbor Freight M/C lift. Here's a link to a post on VSRI that describes it:
http://11109.rapidforum.com/topic=122876521245
post #10 of 11 Old 03-30-2006, 04:52 PM
wingman's Avatar
I had to install a skid plate I bought from Dan Vesel in order to use this lift. Unless you get something like it or make some sort of adaptor, you wont be able to use it with a Strom.
Wingman
2001 GL1800 Blue
2005 DL650 Red
wingman is offline
