Valve checks - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 05-08-2009, 02:05 PM Thread Starter
Bamaboy's Avatar
Valve checks
I just bought a 2004 DL1000 with 20K miles on it. I called one of the previous owners and he said the valves were checked by his brother (A Suzuki mechanic) at about 10K miles.
Should I do another valve check?
Any way to know if it needs one? Weird noises, popping, etc.?
Bamaboy is offline
post #2 of 6 Old 05-08-2009, 02:49 PM
By the time it starts to make weird sounds it's just about too late. If you trust what you've been told about it being checked then you're good to go. If you're handy with tools you could check it yourself. I just did mine and it has 17,000 miles on it. Six of the eight valves needed some adjustment. I would think at 20k yours would need some adjustment also. There's a good sticky on adjusting valves and I posted an addendum on doing the rear cylinder.
gbritnell
gbritnell is offline
post #3 of 6 Old 05-08-2009, 03:39 PM
How much do you trust the previous owner?
Wingspan is offline
post #4 of 6 Old 05-09-2009, 12:50 AM
enumclaw's Avatar
gbritnell
Which sticky are you referring to? I don't see a very current one (not that much has changed), just looking for the latest and greatest before I dive in.
Thanks.
Rob
Ride every day, it's good for you.
07 650A | KLR250(x2) | KLR650 | DRZ400 | FJR
enumclaw is offline
post #5 of 6 Old 05-09-2009, 10:13 AM
post #6 of 6 Old 05-09-2009, 11:00 AM
enumclaw's Avatar
Thanks. I had read through the one started by MS. Your separate addendum is a great tip. Thanks again.
Rob
enumclaw is offline
