Multi-meter - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 12 Old 05-07-2009, 12:34 AM Thread Starter
scrminbanshee's Avatar
Multi-meter
which one r u using and y????
best bang for the buck????
Silver strom #1
f-it you get 2 chances.....
scrminbanshee is offline
post #2 of 12 Old 05-07-2009, 06:55 AM
tmcgee's Avatar
I carry a Fluke meter in my tool bag because I service electronic equipment for a living. I like high quality gear.
tmcgee is offline
post #3 of 12 Old 05-07-2009, 07:09 AM
SNTVSTROM's Avatar
+1 on the Fluke. Quality meters and dependability. Battery life is also better than most.
DL1000K5
Never get to busy making a living, that you forget to make a life....
SNTVSTROM is offline
post #4 of 12 Old 05-07-2009, 08:10 AM
not very quiet
QuietMike's Avatar
I have a Fluke amp-clamp with digital multimeter functions and an inexpensive Craftsman digital which has a rubber-ish armor cover. For simple measurements on the bike, either is fine.
There are occasional situations where an analog meter would be nice. For example, I was checking the trailer plug on my car. I turned on the hazards to see what the voltage was. It was difficult to read, since the digital meters have to see the voltage for a second or so to stabilize. No one was around, or I would have had someone step on the brake so the lights were steady on.
Please don't post just to criticize the question. Either you have an answer or you don't.
QuietMike is offline
post #5 of 12 Old 05-07-2009, 12:31 PM
Sharkey's Avatar
Send a message via Yahoo to Sharkey
Analog and digital
I have both. The analog is an Amprobe Iv'e had for thirty years and a more modern digital. I prefer the analog cause it does'nt jump around.
Sharkey is offline
post #6 of 12 Old 05-07-2009, 12:43 PM
tmcgee's Avatar
A digital meter doesn't jump around either if you get one with a bar graph display in addition to the numeric readout.
There are two times when I prefer an analog meter. The first is when checking transistors or diodes -- I have too many years of Rx100 reference here to switch to the "diode" position of the digital meter. The second is when checking the DC resistance of long lines. A digital meter doesn't have enough current to drive that kind of load.
tmcgee is offline
post #7 of 12 Old 05-07-2009, 12:56 PM Thread Starter
Seeing as i am a complete noob to multi meters but have found more and more places where i need one can somebody please explain the difference in them...and i looked at those fluks which one?????seems they make a lot of them...best bang for the buck...
Silver strom #1
post #8 of 12 Old 05-07-2009, 01:24 PM
msi1259's Avatar
Fluke is probably the best known professional meter out there, but likely overkill for casual use. I have a Fluke mulitimeter and a Fluke scopemeter, but carry a Greenlee PDMM20 on the bike - mainly because it is incredibily small. ( http://www.greenlee.com/product/pdmm-20/start.html ). It is fully automatic - if it sees a voltage, it will display it (autoranges), if it doesn't it will show the resistance. It has a position for testing switch contacts (and shows a graphic switch display), and has a non-contact antenna in it for checking house wiring (like the Greenlee "sticks"). As it is automatic, and doesn't have an ammeter function - it is virtually impossible it destroy. (The Fluke will beep if the leads are in the current position, but the meter isn't - most meters will just act like a short and (hopefully) blow the fuse). The one downside to the Greenlee is it is a little slow to read. (as it tries to auto range the voltages and then do resistance). I bought mine through eBay, usually <$40. (I gave a couple out as Xmas gifts last year).
DL1000K5
msi1259 is offline
post #9 of 12 Old 05-07-2009, 04:35 PM
tmcgee's Avatar
Buy the $20 meter at Radio Shack. If I needed a meter in a hurry, that's what I'd get. If you ever need more than that, you'll know.
tmcgee is offline
post #10 of 12 Old 05-07-2009, 05:06 PM
MacGyver's Avatar
Not quite a Fluke, but a high end Radio Shack digital multi-meter (circa 1995) is what I have for home and garage use. For the bike tool kit I have just the basic Radio Shack (or anywhere) $20 digital multi-meter that uses a lithium battery and is about the size of half a deck of cards. If I really need to use the multi-meter on the road/trail, having a fancy/expensive one would not likely get the big going any faster in my opinion.
Hope that helps,
Tim
TMEGMOTT (too much extra gear most of the time)
2011 V-Strom 650ABS - Back In The Saddle Again!
MacGyver is offline
