Front Axle Bolt - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 05-05-2009, 03:10 PM Thread Starter
ddavidson's Avatar
Front Axle Bolt
What's the size of the hex key I need for the front axle bolt?
Thanks in advance.
---David
87 Honda Magna v45 (wrecked) , 00 Ninja 500R (sold), 07 V-Strom w/ABS (sold), 06 VFR and 82 cb900f
ddavidson is offline
post #2 of 7 Old 05-05-2009, 03:13 PM
AppGap's Avatar
12mm..----
04 Wee with all kinds of excess crap..
AppGap is offline
post #3 of 7 Old 05-05-2009, 03:13 PM
12mm. The only way to know that from your sig is the ABS since the 1000 doesn't have it. 1000s use a 19mm hex.
post #4 of 7 Old 05-05-2009, 03:36 PM Thread Starter
ddavidson's Avatar
Front Axle Bolt
You guys are great. Thanks. Any chance you know the size of the hex bolt (there are 2) on the top of the fairing directly in front of the handle bars. I need to remove these to lift the tank and one of them has been overtorqued...not sure how I'm going to get it loose.
---David
post #5 of 7 Old 05-05-2009, 03:46 PM
4mm. If it rounds off, a pointed punch dug in near the outside edge and driven at an angle will get it loose. It can also have a slot cut across the top for a flat bladed screwdriver. 09139-06122 is the part number for a replacement.
post #6 of 7 Old 05-05-2009, 03:51 PM Thread Starter
ddavidson's Avatar
Awesome. I'll give it a try...
---David
post #7 of 7 Old 05-06-2009, 09:46 AM
Useful Hex Bits?
To follow up, I've got the 650 DL (w/o ABS), what hex bits are useful? Looks like I need a 12mm for the front axle a 6mm for so I can mount my GIVI engine guards, any others that need torquing? I have regular allen wrenches so just need to know what I need for socket drivers. And what's the recommendation for the front axle, 3/8" or 1/2" drive?
(I'd just buy a whole hex set, but I'm restricted on room, have a mountain of tools that don't get used so I'm now into buying just those that I know I'll use.)
Previous ride: Orange Wee Club #34
Mercenary is offline
