Help - Oil Pressure Light Came on. - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 10 Old 05-04-2009, 04:52 PM Thread Starter
ZAR
ZAR's Avatar
Hi,
After a weekend of very hard adventures riding (mud, river crossings, and very rough terrain) in Lesotho I rode back home, about 450km. We rode hard mostly at 160-170km/h. I overtook a Jaguar and the guy floored his car, so I just gunned my DL and passed him. At about 190km/h (speedo speed) the oil light came on. I grabbed the clutch and killed the engine and pulled off the road. I saw now oil leaks and the oil level was ok. I turned the ignition on and the oil light went out when I started the engine as normal. I rode the rest of the way at 160km/s and no problems.
What could have caused this?
Thanx
ZAR is offline
post #2 of 10 Old 05-04-2009, 06:00 PM
rcacs's Avatar
I assume you are refering to the red light in the middle of the dash. When that light comes on, the clock will alternate between the time and FI. This indicates a trouble code. There are several codes that can occur without the engine shutting down. When you turned your bike off and back on again, you erased the code.
My bike has done that twice, but unfortunatly I was unprepared to capture the code. You have to access dealer mode (must remove the seat) while the bike is still running and the light is on.
It may or may not ever do it again. Keep a spare key and paper clip handy so next time so you can capture the code.
Cheers
ps: its very helpful to others if you place your year/model in your signature.
rcacs is offline
post #3 of 10 Old 05-05-2009, 03:14 AM Thread Starter
ZAR
ZAR's Avatar
Thanx rcacs,
I hope it doesnt happen again!
And will ad info in my signature.
ZAR is offline
post #4 of 10 Old 05-05-2009, 07:46 AM
rcacs's Avatar
This morning coming home from work, my light came on again (3rd time) and the FI flashing.
This time I was prepared, having my extra key along.
After accessing Dealer Mode, I recieved C 31 trouble code. This is the gear position switch. According to the manual, each gear position sends a different voltage output to the ECM.
With my mileage, I imagine the switch has just worn out after several zillion shifts. With a ride to Yukon/NWT on the horizon, I shall change out the switch right aways.
Cheers
rcacs is offline
post #5 of 10 Old 05-07-2009, 05:44 AM Thread Starter
ZAR
ZAR's Avatar
Accessing Dealer Mode? How do you do that??
Suzuki DL650 - 2007
Suzuki DL1000 2009 Crashed
Suzuki DL650 2006 Sold
Suzuki GSX750 - 1982 Sold
Suzuki RG50F - 1988 Sold
ZAR is offline
post #6 of 10 Old 05-07-2009, 10:24 AM
http://www.vstrom.info/Smf/index.php/topic,7061.0.html
post #7 of 10 Old 05-07-2009, 11:58 AM
rcacs's Avatar
Thanks for supplying that link GW.
The Zook manual gives no explanation why the gear position switch provides a different voltage per gear to the ECU. I notice absolutaly no change in performance/mileage/function and so far it has only come on 3 times, each time within a few minutes of running on a cold morning, and only once 6th gear was reached. My initial impression of this switch was mearly to ensure the bike couldnt be put into gear with the side stand down but there must be other functions included.
Cheers
rcacs is offline
post #8 of 10 Old 05-07-2009, 12:45 PM
The gear position switch is more important for the DL1000. It has restrictions in just about every gear except 4th.
post #9 of 10 Old 05-07-2009, 02:05 PM
rcacs's Avatar
I knew that one, but wonder why on the Wee?
O well, will just replace it.
Cheers
rcacs is offline
post #10 of 10 Old 05-08-2009, 06:39 PM Thread Starter
ZAR
ZAR's Avatar
Thanx GreyWolf!
Suzuki DL650 - 2007
ZAR is offline
