Hand pump vs air compressor - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
post #1 of 14 Old 10-09-2017, 10:21 PM Thread Starter
Originally Posted by gdrew View Post
is it not possible to inflate a motorcycle tire with one of those tiny bike hand pumps that take up very little room?
Not to hijack the original thread I’m starting a new discussion. I recently purchased a hand pump as a backup for my Slime compressor that tends to overheat after extended use. This weekend my buddy needed to air up his front tire on his Chinese bike with spoked wheels. Not wanting to unload my gear to access the compressor under the seat I grabbed the pump from my tool tube. I was surprised how easily he got from 14psi to 25psi. Later we both aired down for some dirt riding. I happily grabbed my hand pump only to find it wouldn’t work on the cast wheels on my 650. The valve stem was too close to the spoke so I couldn’t attach the pump. I plan to get a short section of hose with an adapter to put on the valve stem in order to connect the hand pump.
wingstrom is offline
post #2 of 14 Old 10-09-2017, 10:29 PM
RCinNC's Avatar
If adapting the old pump doesn't work, you could try something like this one:
Sorry, I forgot to include the manufacturer's name: It's made by a company called GIYO.
wingstrom likes this.
RCinNC is offline
post #3 of 14 Old 10-09-2017, 10:45 PM
MrF
MrF's Avatar
I have a similar one on my road bike... bicycle that is. Topeak Road Morph I think is the model. I run 80-110 psi depending on the road and it'll get up there with no problem. If you get a bicycle specific pump like that, just make sure it'll fit our Schrader valves. Topeak's will do both, but some brands will only fit presta valves.
2016 V-Strom 650
MrF is offline
post #4 of 14 Old 10-09-2017, 10:48 PM
If you find one that works, in the interest of science, try hand-pumping a tire from flat to see how long it takes and report back here.
-Gary
2016 GSX-S1000FA
2012 DR650SE
2011 Burgman 400
2007 Honda Helix
2013 V-Strom 650 - sold
G-Dub is offline
post #5 of 14 Old 10-09-2017, 11:49 PM
MLS2GO's Avatar
Yes. It is also possible to make all your own clothes from spinning cotton, but its much more prudent to buy them already made. If you have a slow leak say even with a plug installed, it may take you a week to get somewhere to get it fixed. Another scenario, you have a flat on a busy interstate. Inflating quickly may save your life. Buying an electric pump IMHO is the way to go.
Bob Rippy
2012 DL650 Adventure
2014 BMW R1200RT
Missouri State Sponsor of WWW.TOUROFHONOR.COM
IBA #451
MLS2GO is offline
post #6 of 14 Old 10-10-2017, 09:39 AM
chicago's Avatar
oh yeah, my R75/6 had a hand pump (oem) affixed to the frame.
I have one of these on my bicycle. though I've never tried this on the bike it seems like a good option to have.
14 tooth for me
chicago is offline
post #7 of 14 Old 10-10-2017, 10:24 AM
I would agree, it would be nice to know if pumping up a motorcycle tire in a reasonable amount of time is doable with a quality built bike tire hand pump. When I say reasonable amount of time I'm thinking in the 10 minute range. If a mini hand pump works I'll be putting one on my 650 as part of its permanent complement of tools.
gdrew is offline
post #8 of 14 Old 10-10-2017, 11:01 AM
A friend had a double action hand pump for his motorcycle needs. It seemed to work fine when I used it but that was on a tube type tire. Not sure it would have any affect of a just mounted tubeless tire.
post #9 of 14 Old 10-10-2017, 11:13 AM
chicago's Avatar
yeah I think once the bead of a tubeless is broken you need a burst of air to seat the tube. creative use of a strap may help. also there is the starter fluid explosion trick.
14 tooth for me
chicago is offline
post #10 of 14 Old 10-10-2017, 12:17 PM
I have a couple lezyne pumps for my bicycles and they are the cat's meow! You would be there for a few hours trying to pump up a motorcycle tire though!
NMThumper is offline
