Another chain adjustment mystery - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 04-27-2009, 11:28 PM Thread Starter
rodr's Avatar
Over the weekend I adjusted my chain for the first time. It had about 1.5 inches of slack and I corrected it to about 1 inch.
After about 10-20 miles of riding, I checked it again today. The slack is back to 1.5 inches. The adjustment markings at the axle are still where I left them after adjustment.
What does this mean? The bike has only about 2000 miles on it.
Rod
Orange Wee Club member #18
DL650K9 with Murphs center stand, SW Motech Rally crash bars, Madstad bracket, Dan Vesel luggage guard and tube,
Bestem top box, Nelson Rigg CL-850 saddle bags, Rapid Transit Abrams tank bag, Beadrider, SH-775 R/R
rodr is offline
post #2 of 6 Old 04-27-2009, 11:45 PM
A chain needs more adjustment at the beginning of its life and at the end. It will calm down.
post #3 of 6 Old 04-28-2009, 12:31 PM
It means the chain warmed-up and expanded. Let it cool off again and check it...
gijoecam is offline
post #4 of 6 Old 04-28-2009, 02:43 PM Thread Starter
rodr's Avatar
Yeah the chain is still quite new, and the last measurement was cold. I adjusted it again and will keep an eye on it. Thanks for all the replies.
Rod
rodr is offline
post #5 of 6 Old 04-28-2009, 04:15 PM
Stromtrooper.com Sponsor
Satch's Avatar
+1 on the warm chain vs. cold chain. Also it makes a difference if you check it on the side stand vs. up on the center stand. You should check it while it's resting on the side stand.
:arrow: Follow the V-Strom Cache Adventure | See Where the Cache has Been | Play the Stromtrooper Picture Game | Play the Weekly Picture Game
Preferred V-Strom Model Nicknames: 02-12 DL1000 Vee, 2014+ DL1000 ABS Vee2, 04-11 DL650 Wee, 12-16 DL650 Wee2, 17+ DL650 Wee3
V-Stroms I've owned: Wee.07, Wee.11, Wee2.13. Currently Wee-less
Satch is offline
post #6 of 6 Old 04-28-2009, 06:38 PM
jackpiner57's Avatar
The cheap stock chain has a fairly low tensile strength compared to a quality chain. It is a rubber band. Expect to adjust it often if you like to twist the throttle. Also, all chains have a tight spot. Elevate the rear wheel and turn it to find where it is the tightest. Leave it where it's tightest and then lower it onto the sidestand to adjust it. I suggest putting some anti-seize lube on the axle and torque it to 62 ft. lbs. This will help your axle last longer by preventing thread galling.
"Build a man a fire and he'll be warm for the night. Set a man on fire and he'll be warm for the rest of his life." - Confuseus
jackpiner57 is offline
