2014 DL1000 DC "Lighter Plug" outlet not working - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 09-24-2017, 10:50 PM Thread Starter
Raybanman's Avatar
Had my bike in for the wiring harness recall about a year and a half ago, and they had to replace it. Ever since, the lighter plug hasn't worked. I checked it at the plug with it running - no power, removed the dash, checked the wires at the connector with it running - no power, finally checked the plug itself and I have continuity in the plug.
Anyone know if there is a spot downline somewhere where there is a connector that is could be loose? I pulled off all the plastic I could short of removing the tank - which I would hate to do, but might tackle over the winter if I had to.
Fuses seem fine under the seat... anyone know if it has it's own fuse hidden somewhere?
I have the Suzuki maint. manual, but it doesn't seem to think that DC plug system is even worth mentioning as I can't find it anywhere.
Thanks in advance!
-2014 VStrom 1000
-2010 Honda Shadow Phantom
“Exploration is in our nature. We began as wanderers, and we are wanderers still. We have lingered long enough on the shores of the cosmic ocean. We are ready at last to set sail for the stars.”
― Carl Sagan, Cosmos
Raybanman is offline
post #2 of 7 Old 09-25-2017, 01:50 AM
Did you see the spare fuses in the cap? That 3 amp is easy to blow.
moglink is offline
post #3 of 7 Old 09-25-2017, 11:57 AM Thread Starter
Raybanman's Avatar
No! I didn't see them! That would be great if it was just a fuse haha! Where exactly is the fuse for this?
Thanks!
-2014 VStrom 1000
post #4 of 7 Old 09-25-2017, 12:45 PM
It's the first fuse in the #10 fuse box under the seat.
post #5 of 7 Old 09-25-2017, 12:50 PM Thread Starter
Raybanman's Avatar
Ok, awesome, I'll switch it out! Thanks! I tried to discover which one the outlet was on from the maint manual, but no luck.
-2014 VStrom 1000
post #6 of 7 Old 09-25-2017, 01:01 PM
The top of the box has a list of what the fuses are for.
post #7 of 7 Old 09-25-2017, 08:27 PM Thread Starter
Raybanman's Avatar
Ok, awesome. That fixed it. It didn't look gone, but was. Thanks! I didn't realize "P-source" was for the DC plug!
Cheers!
-2014 VStrom 1000
