DL650 stumble - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 8 Old 03-20-2006, 11:38 PM Thread Starter
DL650 stumble
My 06 DL650 has started having a stumble or hesitation at idle. Runs fine under a load but while idling at stop lights or just sitting, the engine will stumble or hesitate. Occasionally it will die. Starts again with no prob. 5,000 miles. Any ideas?
Thanks,
Don Braziel
IBA#12079
STOC #5466
100CCC, SS5000
2006 DL650 WeeStrom
2004 GL1800A Goldwing
Burleson, Texas
Braz is offline
post #2 of 8 Old 03-21-2006, 03:14 AM
Braz, what is your idle speed(RPM) ? Maybe it dropped off a bit. Maybe a tank of bad gas ? Probably something simple. Good luck.
05 / 650 in blue
88 / KDX 200 in green
81/82 DT 175 Yamahussies
78/ GT 750 water pumper
75/Suzuki 125 RV
water warrior is offline
post #3 of 8 Old 03-21-2006, 08:13 AM Thread Starter
Stumble
Idle speed is about 1400. Just installed an Audiovox Cruise last weekend. Had not noticed this before that but everything works well other than the hesitation.
Don Braziel
IBA#12079
STOC #5466
100CCC, SS5000
2006 DL650 WeeStrom
Burleson, Texas
Braz is offline
post #4 of 8 Old 03-21-2006, 08:57 AM
wingman's Avatar
Not sure if it helps but I had a similar problem right after I installed my Audiovox. However, my bike was winterized with Stabile in the gas tank and this thing went away after 4 or 5 starts and I attributed it to the bike's system working itself out after months or non-use. It could also be that you have a leak in the pressure hoses that were connected to your Audiovox.
Wingman
2001 GL1800 Blue
2005 DL650 Red
wingman is offline
post #5 of 8 Old 03-21-2006, 09:32 AM
Hey Braz, I had a thought about the stumble etc. Was the idle speed always about 1400 or a little lower as the manual recommends ? And does the cruise control have a vacumn control of any kind ? A vacumn leak would or could raise the RPM a bit and the lean mixture might be enough to upset the Wee. Of course I could be totally wrong and leading you astray. Keep us informed, I want to know what can upset such a nice running power plant.
05 / 650 in blue
75/Suzuki 125 RV
post #6 of 8 Old 03-21-2006, 06:23 PM Thread Starter
There is a vacuum canister on it with a check valve. All the hoses have been checked and appear to be well seated. Weird. Please keep the thoughts coming.
Don Braziel
IBA#12079
STOC #5466
100CCC, SS5000
2006 DL650 WeeStrom
Burleson, Texas
Braz is offline
post #7 of 8 Old 03-21-2006, 06:46 PM
Send a message via Skype™ to torqueman
Did you get the air cleaner back together correctly? It took me a little bit of wiggling and such to get a tight seal.
Also did you use the RC airplane clevis or a taped screw? I tried to use the clevis but the throttle would not close all the way with it in place so I went with the screw.
torqueman is offline
post #8 of 8 Old 03-22-2006, 03:44 PM Thread Starter
Tapped screw. The air cleaner might be somethingto check. Thanks,
Don
Don Braziel
IBA#12079
STOC #5466
100CCC, SS5000
2006 DL650 WeeStrom
Burleson, Texas
Braz is offline
