HELP! torque specs front and rear axles - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 04-25-2009, 01:26 PM Thread Starter
2tall's Avatar
Sorry if I've missed this somewhere. Did a search but couldn't find it. Can't find my shop manual either, so I'm stuck with "seems tight" for now.
Can anyone provide me with the torque specs for the following?
rear axle nut
front axle
front axle pinch bolts
front brake caliper mount bolts
It's a nice day and I want to go riding. Just got new tires mounted and back on the bike, but am stuck without my shop manual.
Thanks in advance.
John
johnvstrom at yahoo.ca.............. V-Stromming since '03
'06 DL1000 Grey
'03 DRZ400$ sold, down to one bike
2tall is offline
post #2 of 6 Old 04-25-2009, 01:50 PM
This information is from the DL650/A service manual for years '05-'08.
Rear Axle Nut 72.5 lb/ft
Front Axle 47 lb/ft
Pinch Bolt 16.5 lb/ft
Caliper Mounting Bolts 28 lb/ft
I hope this helps.
Mike
j3226287 is offline
post #3 of 6 Old 04-25-2009, 02:38 PM
All seem a little on the strong side but only the rear axle spec has caused many problems. Stainless on stainless likes to gall or cold pressure weld. I like to use anti seize and a reduction in torque to make up for the lubrication effect to 55-60lb-ft.
post #4 of 6 Old 04-25-2009, 07:20 PM
I agree, and I think I saw where most others agree that >70 on the rear is too much.
hojo is offline
post #5 of 6 Old 02-26-2015, 08:33 PM
VtSTROM-K5's Avatar
Send a message via Yahoo to VtSTROM-K5
Looking for the front and Rear axle nut size's please I think 32 for the rear but no idea on the front.
...Thanx
OK found the rear axle nut Size is 36mm not 32mm...
2014 V2 DL 1000 25 miles and Onward
IF I only Rode in Good weather..
I WOULDN'T get to Ride in Vermont.at ALL!
we have 2 types of roads in Vermont, Unpaved roads and decaying back to .............Unpaved roads..
2005 DL1000 98,547 miles and continuing in the hands of it's new owner
VtSTROM-K5 is offline
post #6 of 6 Old 02-26-2015, 10:57 PM
The front isn't as big a deal, 'cuz of the pinch bolt that holds the axle bolt.
