Sprocket compatibility - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
post #1 of 12 Old 08-17-2017, 11:43 PM Thread Starter
marcoma's Avatar
Ok my 2013 glee has passed 64000 miles and I figure its time I treated it to a new drivetrain. Yup, I'm still on my original sprockets and quite frankly they look like new but Ima do it anyways.
Looking online, most places advertise kits up to 2012 but very few for later models. I always thought the wee's and glee's had exactly the same drivetrain and chain length - is that true?
I'm also looking at tapered head bearings and the same issue is happening - everything stops at 2012....
marcoma is offline
post #2 of 12 Old 08-18-2017, 08:59 PM Thread Starter
marcoma's Avatar
Anyone?
....Bueller......?
marcoma is offline
post #3 of 12 Old 08-18-2017, 09:06 PM
locoblanco's Avatar
I'm not sure what the difference is between a wee and glee, but Denniskirk.Com has chain and sprocket kits for reasonable prices. I recommend RK brand, I have used them on other bikes and they are long lasting.
For best results chain and sprockets should always be replaced as a set.
locoblanco is offline
post #4 of 12 Old 08-18-2017, 10:22 PM
2007-2016 uses the same chains and sprockets.
post #5 of 12 Old 08-18-2017, 10:43 PM Thread Starter
marcoma's Avatar
Thank you, O Oracle!
marcoma is offline
post #6 of 12 Old 08-19-2017, 12:57 AM
blaustrom's Avatar
Get the OEM kit, not the individual components. Competitive price, RK chain, can use the RK riveting tool, OEM front sprocket with damper ring. They come in standard, I think 120 links, length and need to be cut to your bikes length. Just measure/ count the old one. You will need to press out one pin of the new chain to correct the length.
Just one example: http://www.oneidasuzuki.com/store/pa...-sets-oem.html
blaustrom is offline
post #7 of 12 Old 08-19-2017, 05:36 AM
Motor7's Avatar
64K on one set of sprockets? Same chain? Holeey crap..........
Mulewright likes this.
'15 DL650XT
Motor7 is offline
post #8 of 12 Old 08-21-2017, 05:00 PM Thread Starter
marcoma's Avatar
No 3 or 4 chains, same sprockets. She still has the oem sprockets and they look fine (well the rear one does) but I'm going to change them all next round.
marcoma is offline
post #9 of 12 Old 08-21-2017, 08:42 PM
Motor7's Avatar
Even so, that's amazing. I put a new 14T front sprocket on at about 6K miles, it was visibly hooked at 20K, so done in a total of 14K miles. I've been lubing almost every tank full.
'15 DL650XT
Motor7 is offline
post #10 of 12 Old 08-21-2017, 08:49 PM
chicago's Avatar
yes 15k or so is what I get with front sprockets. I lube often.
14 tooth for me
chicago is offline
