What is it? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
  • 1 Post By Spec
  • 1 Post By esacfrank
post #1 of 7 Old 08-04-2017, 10:19 AM Thread Starter
esacfrank's Avatar
What is it?
I admit it, I am a tool slut. If I see a hand tool I think I may need sometime in my life I will buy it.
So I was cleaning out my tool box the other day and came across this. I assume I bought it but for the life of me I don't know when or why. The only thing I know for sure is that it is for a bike, car or aircraft and not a boat.
So I'm calling on the group expertise to help me identify what it is and what it does.
It's a 10" long steel rod bent 90 degrees at the 4" mark with a 3/4" nut attached (braized?) on the end.
Frank
2012 DL 650A
Newington, CT
STOC#205
esacfrank is offline
post #2 of 7 Old 08-04-2017, 10:36 AM
Spec's Avatar
Muffler bearing adjustment tool.
The bearing threads onto the tool but you need the right angle access.
iamsmiling likes this.
Spec is offline
post #3 of 7 Old 08-04-2017, 10:58 AM Thread Starter
esacfrank's Avatar
more like a blinker fluid level adjuster.
Frank
2012 DL 650A
Newington, CT
STOC#205
post #4 of 7 Old 08-04-2017, 11:10 AM
If had not seen the threads would have guessed a old points type car motor tool to move Dis..when tuning.What ever it looks like a good one! Must be a hold for a nut while you adjust a stud IMO.
Old Time Rider is offline
post #5 of 7 Old 08-04-2017, 11:13 AM
Spec's Avatar
Nope doesn't have the hydraulic actuator coupling.
Spec is offline
post #6 of 7 Old 08-04-2017, 11:16 AM
For use with another nut as a stud extractor/installer was my first thought, but it seems like a lot of work to replace a nut and wrench. Do you braze? Is it something you could have made?
post #7 of 7 Old 08-04-2017, 03:13 PM Thread Starter
esacfrank's Avatar
Mystery solved by Mellow on the ST1300 list. It's the handle for a progressive shock compression tool. I had the handle in my everyday tool box and the rest in my tool chest. Shows how much I used it. I think I got it around 2005 when we were changing the springs on a 1998 VFR.
Thanks Mellow
Frank
2012 DL 650A
Newington, CT
STOC#205
