side stand removal - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 04-09-2009, 04:24 PM Thread Starter
Question side stand removal
Just bought a k7 wee that's been lowered, but they didn't shorten the side stand. A friend is waiting for me to bring the side stand over so he can fix it.
So far I've removed the spring clips, taken off the nut, but can't budge the bolt. Is there a trick or do I just need a bigger hammer?
owlarry is offline
post #2 of 5 Old 04-09-2009, 04:26 PM
No longer riding.
handyhiker's Avatar
The bolt is threaded in to the bike that holds the side stand on.
Totaled on June 9 2012 08 Victory Vision Tour Premium.
No longer riding due to injuries on June 9 2012.
handyhiker is offline
post #3 of 5 Old 04-09-2009, 04:46 PM
Basso's Avatar
So you have removed nut 3 and you are trying to remove bolt 2? I'd guess it is pretty well threadlocked, so I'd go with a really long arm ratchet or a breaker bar, but I've also destroyed things trying to remove them, so you probably shouldn't listen to me
[SIGPIC][/SIGPIC]Bikes: '08 Suzuki Bandit 1250 ABS; '07 DL650 ABS - SOLD; '08 DL650 -SOLD; '07 Suzuki M50 - Sold
IBA# 33667
Basso is offline
post #4 of 5 Old 04-09-2009, 04:51 PM
High strength threadlock is used there. Use heat to defeat it.
post #5 of 5 Old 04-09-2009, 04:59 PM Thread Starter
Thanx. I wedged a wrench on the bolt head and used the stand itself as a breaker bar. Since the threads were in the outside part of the yoke, it loosened right up. Clever how they used nut 3 as a double-nut to keep it secure. The last mechanic used Loc-tite to make sure it didn't come loose!
owlarry is offline
