TB Manometer - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 03-04-2006, 07:33 AM Thread Starter
TB Manometer
I did a search but couldn't find the article that described the construction of the home built manometer for synchronizing the throttle bodies. It used oil in the tubing.
Any help in finding the url appreciated.
Andy
afmeyer is offline
post #2 of 4 Old 03-04-2006, 08:21 AM
Gilk51's Avatar
Here is what is on the Wiki:
http://vstrom.info/cgi-bin/moin.cgi/...y_sync_tool%3f
.......Chuck
blue '04 DL-650
dark cherry '07 FJR
AARP member!
Gilk51 is offline
post #3 of 4 Old 03-05-2006, 09:52 PM
I made my own back when I had my ZR-7S. It's a lot more involved for a four but still not that hard. I replumbed it for the DL and it worked like a charm. I use rubbing alcohol instead of water or ATF so if it gets sucked into the TBs, it will just mix with the gas and burn away. The advantage of ATF, though, is that it moves a little slower so you don't get the jittery effect.
06 DL-650 - SilverBlue
05 DL-650 - red (RIP - watch your mirrors!)
TomG is offline
post #4 of 4 Old 05-15-2006, 10:56 PM
maxmosbey
I used 2 cycle oil in mine.
