2015 dl650a tank removal - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By greywolf
post #1 of 4 Old 05-18-2017, 03:38 PM Thread Starter
Can I please get some direction on how to remove the fuel feeder line from the tank?
Jasbear4u2 is offline
post #2 of 4 Old 05-18-2017, 04:30 PM Thread Starter
I did read on here to squeeze the blue tabs on the attachment to remove the fuel line. I have tried this several times without luck.
post #3 of 4 Old 05-18-2017, 04:59 PM
Try pushing the hose into the tank spigot to ease the pressure on the blue clip, then squeeze the clip ears together. The clip stays on the spigot and the black part comes away so you need to squeeze the blue part only.
duckiemonster13 likes this.
post #4 of 4 Old 05-18-2017, 10:36 PM
When you reinstall the gas line, be sure you push it all the way in until it clicks. Give it a tug to be sure you've engaged the blue clips.
