Givi E52N brake light wire routing question... - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 03-02-2006, 08:53 PM Thread Starter
I just mounted a Givi E52N on my DL1000. This top case has built in brake lights.
Does anyone have a clever wire route which:
1) hides the wire away from sight and catching on anything
2) doesn't get it flattened by the seat
3) doesn't put holes in the bike where water can seep in during riding or washing
Oops, got this in the wrong forum, was aiming for V-Strom Modifications and Performance Sorry...
ejy712 is offline
post #2 of 6 Old 03-03-2006, 08:48 PM
subagon's Avatar
This should answer your questions;
http://cycle.frogfruit.com/main.php?...m&g2_itemId=13
I don't like making changes to my bike that I can't remove i.e. holes. The hardest part was tapping into the brake lines way back near the tail light. Took less than an hour.
Click on the pictues to get larger images and short test description. You can also select a very high rez images after you click on the image (look in the upper righ ahnd corner)
Mike
Tampa, FL
DL650K5
subagon is offline
post #3 of 6 Old 03-04-2006, 09:26 AM
Vordak's Avatar
Location: Eastern Ontario, Canada, Earth, Solar System.
E52 Light kit
hello,
Does the Givi supplied wire splices cut in to bot wires? Which wire did you cut in? I'm having a hard time figuring out which wire to splice in.
cheers!
Never Argue with an idiot, first he'll bring you down to his level, then he'll beat you with experience...
1986 FZX750R Fazer-Should've never sold it!
1986 BMW K75-Old smoker! Good bike. Sold.
2003 DL 1000 Bumble Bee, farkled! Sold.
2006 Honda Goldwing Navi AL.
Vordak is offline
post #4 of 6 Old 03-04-2006, 10:59 AM
subagon's Avatar
Re: E52 Light kit
Originally Posted by Vordak
hello,
cheers!
As I remember you splice into the two wires running to either one of the rear tail lights. You can pull one of the light/bulb assembly out (as if you were changing a bulb) to make the splicing easier.
Mike
Tampa, FL
DL650K5
subagon is offline
post #5 of 6 Old 03-05-2006, 09:50 AM Thread Starter
Thank you subagon. I looked at your photos. Then went and did it. Worked well.
ejy712 is offline
post #6 of 6 Old 03-06-2006, 08:03 AM
Vordak's Avatar
Brake light
So by cutting into just on e set of wires (Both on the same side), I will have a complete circuit that will provide enougb power for both brake light LED's?
If that's all, then it's great! Can't wait to try it.
Cheers
Vordak is offline
