Oil Drain Plug Washer - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 28 Old 02-27-2006, 08:13 PM Thread Starter
Does the oil pan drain plug on the DL1000 have a washer?
afmeyer is offline
post #2 of 28 Old 02-27-2006, 10:14 PM Thread Starter
I notice that there have been 13 views and no responses. Either the question isn't clear, no one who read it changes their own oil, or no one wants to answer. Which is it?
Andy
afmeyer is offline
post #3 of 28 Old 02-27-2006, 10:45 PM
2003strom
Yes, it does have an aluminum crush washer...part #470153-001 on www.bikebandit.com.
Dennis
post #4 of 28 Old 03-01-2006, 03:10 AM
Does this mean the plug washer should be replaced every oil change because it is crushed from the last oil change ?
05 / 650 in blue
88 / KDX 200 in green
81/82 DT 175 Yamahussies
78/ GT 750 water pumper
75/Suzuki 125 RV
water warrior is offline
post #5 of 28 Old 03-01-2006, 03:13 PM
It will be less likely to leak if you replace it, but replacement is not mandatory. You might take the washer and the plug to your local auto parts store and try to match it with a new one...some are rubber coated.
Not worth paying to have one shipped, IMO.
Blue DL650K5
sciroccojim is offline
post #6 of 28 Old 03-01-2006, 09:17 PM
I would replace it if the drain plug was seeping oil when properly torqued. You should get at the very least, 5 oil changes without worrying about the washer.
06 DL-650 - SilverBlue
05 DL-650 - red (RIP - watch your mirrors!)
TomG is offline
post #7 of 28 Old 03-26-2006, 12:28 PM
...a Honda 12 mm will fit. Could be much cheaper than the OEM Suzuki part. I usually change them when...well...they look "crushed" !
"If stupidity got us into this, why can't it get us out?: -- W. Rogers
Oldbindlestiff is offline
post #8 of 28 Old 03-26-2006, 12:57 PM
Heavy's Avatar
Re: Oil Drain Plug Washer
Here's a good site to bookmark for future reference:
http://www.ronayers.com/fiche/getyea...su&groupid=240
Yes it does have a washer. See items #23 and #24
http://www.ronayers.com/fiche/300_03.../crankcase.bmp
Heavy is offline
post #9 of 28 Old 03-31-2006, 01:36 AM
I'm not replacing mine until it starts leaking. Has anyone had to replace their washer because it starting leaking?
My car drain plug and washer look exactly the same and it never has leaked after at least 15 oil changes.
'06 DL1000 - Grey
'89 GSXR 1100
'85 GS550E (Suz)
'75 Yamaha MX250B
'73 Yamaha MX125
Keep your feet on the pegs and your hand on the throttle.
ChrisW123 is offline
post #10 of 28 Old 03-31-2006, 02:14 AM
Chris, I tend to agree with your thoughts but here is another to consider. What materials are used for cars and bikes. Different metals could make the difference with your car parts having a longer service life. Maybe, maybe not. Strom On.
05 / 650 in blue
75/Suzuki 125 RV
