Scottoiler/throttle bodies - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 02-22-2006, 05:19 AM
Luke
Hi all, I'm trying to fit my Scottoiler kit at long last!
Unfortunately, I have got stuck at the first step...
I need to find the outlet on the bottom of the throttle body to run a vacuum hose to the kit.
Trouble is, I cant find it! Is this going to be one of those jobs where the tank has to come off, or can the underside of the throttle bodies be seen with the tank in place?
Any help would be gratefully received,
Cheers
Luke
post #2 of 7 Old 02-22-2006, 06:30 PM
Send a message via Skype™ to torqueman
I think the tank does have to come off. It would be nice if someone could post pictures as I need to tap into that too for the cruise control.
torqueman is offline
post #3 of 7 Old 02-23-2006, 05:58 AM
MATTMAN's Avatar
The back TB has two vacuun ports (one extra for accesories). Look for info on TB syncing for pictures.
650...Anything more than a handfull is wasted
MATTMAN is offline
post #4 of 7 Old 02-23-2006, 11:23 AM
StromTrooper.com Founder
Howboucha's Avatar
Howboucha is offline
post #5 of 7 Old 02-23-2006, 01:01 PM
Luke
Thanks, but I've already got that sheet.
It just doesn't say if the outlets are accessible without having to remove the tank.
I just don't want to remove it unless I absolutely have to :-(
How hard is it to remove the tank on the DL? How much plastic will I have to remove?
Cheers
post #6 of 7 Old 02-25-2006, 06:16 AM
Luke
I got this email from Scottoiler customer support:
if you look from the left side of the bike (with the aid of a torch), up between the "V" of the cylinders, the spigots with rubber bungs are on the under side of the throttle bodies. As space is a little tight, its a good idea to attach the vacuum tubing to the damper elbow before trying to push it onto the spigot. You should not have to remove the fuel tank.
The guidance was spot on. As soon as I looked up where they said, I could see the brass outlet.
All sorted now, and without having to take the tank off!
post #7 of 7 Old 02-25-2006, 04:47 PM
Howboucha's Avatar
I hope for their US customers they use "light" instead of Torch. :lol:
That would be real bad if someone actually uses a torch on their tank.
100% free webcam site! | Awesome chicks and it is absolutely free! | Watch free live sex cam - easy as 1-2-3
