V- Strom Service and Maintenance - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 12 Old 02-07-2006, 03:33 AM Thread Starter
Just a quick question. do the wee and the vee use the same size allen wrench for the front axle ? i have a wee. thanks ahead of time for your reply.
05 / 650 in blue
water warrior is offline
post #2 of 12 Old 02-07-2006, 08:39 AM
MATTMAN's Avatar
The Wee uses a 12mm. A 1K owner might be able to confirm if this is the same for the big bike.
650...Anything more than a handfull is wasted
MATTMAN is offline
post #3 of 12 Old 02-07-2006, 09:17 AM
1000 is bigger
I'm 99 percent sure.
I made a tool for mine and I believe the bolt/nut size I used takes is 3/4 inches. Something like 17 or 19 mm.
03 DL1000
98 R1100RS
98 Ducati 900SSFE
02 Polaris 6X6 (Bucky)
BmwDuc is offline
post #4 of 12 Old 02-07-2006, 09:37 AM
The front axle on the 1000 is a 19mm hex.
Let's go!
05 DL1000
Mountaintime05 is offline
post #5 of 12 Old 02-07-2006, 10:10 AM
subagon's Avatar
DL650 = 12mm
DL1000 = 19mm
See this thread;
https://www.stromtrooper.com/forum/vi...590&highlight=
Mike
subagon is offline
post #6 of 12 Old 02-07-2006, 04:31 PM Thread Starter
WOW ! lots of options . thanks guys an gals all over. now i have to make a decision best suited for my tool kit. that nuts and bolt thing looks good and the spark plug socket is a two in one tool that i like. i know i have a box of plug sockets hiding here somewhere. many thanks. keep the shiny side up.
05 / 650 in blue
post #7 of 12 Old 02-08-2006, 01:07 AM Thread Starter
okay i am back. tried the spark plug socket and it was too big. maybe i will just get my act together and measure the front axle and then go to the local bolt supply house. but it was fun digging through the old tool box.
05 / 650 in blue
post #8 of 12 Old 02-08-2006, 08:49 PM Thread Starter
okay, i am back again. measured the front axle and i will need a 12 mm allen wrench. guess i will just bite the bullet and buy the right tool.
05 / 650 in blue
post #9 of 12 Old 02-08-2006, 09:08 PM
Being in Canada, you might have better luck finding a 12mm Allen wrench. It's a PITA here to find anything over 10mm.
I finally found a 12mm standard L-shaped Allen wrench at Sears. I trimmed about 3/4 in. off with a Dremel cutting disc and used a 12mm hex socket to loosen and tighten the axle.
06 DL-650 - SilverBlue
05 DL-650 - red (RIP - watch your mirrors!)
TomG is offline
post #10 of 12 Old 02-09-2006, 12:23 AM Thread Starter
so much for canada. joe at the bolt store found a 12 mm in cleveland. but i will try sears. the only ones locally come in sets and go up to 10 mm only. oh well, now i have a purpose to get up in the morning.
05 / 650 in blue
