Where's the horn? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 10 Old 01-30-2006, 02:55 PM Thread Starter
Where's the horn?
I'm mounting a Stebel air horn, and I need to know where the stock horn is to tap into the wiring harness. Also-is there a relay with the stock horn or is it directly wired?
Thanks!!!
Fourvalve is offline
post #2 of 10 Old 01-30-2006, 03:07 PM
Compared To What?'s Avatar
Left side behind the radiator (6Fiddy).
Compared To What? is offline
post #3 of 10 Old 01-30-2006, 08:28 PM
csr67's Avatar
Stebel Horn
I don't think there is any relay on the stock horn. When you unplug it from the stock horn, take a look how wimpy wiring is, it's not much bigger than a piece of string. I would seriously plan on running the relay that comes with the stebel. I wired my to a in-line fuse directly to the battery. You can extend the stock horn lead to your new horn using spade connectors in the stock plug. I mounted mine on the left side of the front fairing like many others. Do a search and you'll find some tips for this install. I used a large hose clamp to mount it to the fairing support bracket, and it was very easy once you remove the left cowl. Have fun and enjoy that horn. It's by far the best addition that I have added, and I've scared the living sh*t out of a few lousy drivers who don't pay attention. :shock:
csr67 is offline
post #4 of 10 Old 01-30-2006, 08:35 PM
I mounted up the Griot "version" (right side of the fairing, in the VEE) a year ago using velcro. Ran my wiring from the OE connector over the frame to the right hand side. No relay needed (so far). VERY LOUD!
post #5 of 10 Old 01-30-2006, 08:41 PM
Stebel install pics
Fourvalve .. some pics when you get the install done. I ordered a Stebel horn as well but haven't got it yet. I intend to use the relay as the horn will need lots of juice to put out that 139db. Enjoy.
pilgrim is offline
post #6 of 10 Old 01-30-2006, 08:50 PM
Send a message via Skype™ to torqueman
I am not worried about the wires getting too hot as I doubt the current will run through them long enough to do anything. You only us your horn for a few seconds. What does concern me is screwing up the switch with that high current. So I will use the relay.
torqueman is offline
post #7 of 10 Old 01-30-2006, 09:47 PM
csr67's Avatar
I originally wired mine direct to the stock horn wires w/o a relay. It worked just fine. Then a read about another rider who burned out the horn switch because of the high draw from the Stebel. Since you must replace the entire pod to replace the horn switch ($$$), I figured adding the relay would be the way to go. It only took about 30 minutes for the whole re-wiring project.
csr67 is offline
post #8 of 10 Old 01-30-2006, 10:09 PM
Gilk51's Avatar
I also second the use of the relay. It's included with the Stebel, so you just need more wire. Just use the horn button to power the relay coil.
My installation - right side of cowl:
.......Chuck
blue '04 DL-650
dark cherry '07 FJR
AARP member!
Gilk51 is offline
post #9 of 10 Old 01-30-2006, 10:45 PM
Same side installation, different method. . .
post #10 of 10 Old 01-31-2006, 12:11 AM Thread Starter
Thanks for the info, folks!
I ordered a horn relay kit from Eastern Beaver (excellant, high quality products!) and will use the stock horn wiring to trigger the relay. (I've already used the relay that came with the Stebel for an automotive project. The Eastern Beaver kit is super-slick.) THANKS for the pictures! I'd originally zip-tied the horn just below the fairing onto the frame rail, but inside the fairing looks like a much more elegant solution.
