Battery overflow - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 2 Old 01-25-2006, 05:45 PM Thread Starter
Battery overflow
The bike's stored for the winter, and I left the battery in it (as I always have). I have one Battery Tender Plus that I rotate between 3 bikes. OK, so I'm cheap! The past couple of times that I hooked it up to the Strom, I noticed that a wet spot appeared on the floor below the overflow hose. This hasn't happened with the other bikes. Any thoughts on what could cause this?
K4 DL1000 V-Strom
Ninja 500
Seca 550
GT500
GT500 is offline
post #2 of 2 Old 01-30-2006, 01:11 PM
prof's Avatar
Disclaimer - I am not an expert, but since no one else responded to your post, take the following for what it is worth.
Sounds like you are boiling off water because the battery is getting too hot when connected to the charger. Pull the battery and check the water levels.
If I am not going to ride all winter I pull the battery, make sure it is fully charged, then store it inside. A lot of batteries get fried because of a problem with the tender. My friend had to replace the battery in his BMW GS last spring because his tender fried the battery sometime over the winter. Of course, it is more difficult to remove the battery from his bike since you have to raise the tank. Since it is so easy to pull the battery in the Vstrom, it makes sense to do that over the winter.
prof
prof is offline
