Smokey exhuast - one side only - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 8 Old 12-24-2005, 05:07 AM Thread Starter
Have an 02 DL1000 which is a joy to ride -
When I start up from cold I'm puzzled why only one exhaust (left side) smokes and the other doesn't? Is it a sympton of something - maybe an unbalanced carb?
Curious to know .... :?
Thanks - and Happy Christmas to all.
'02 Blue DL1000 - riding with a smile
Simbad is offline
post #2 of 8 Old 12-24-2005, 05:46 AM
Blue smoke that goes away shortly after the bike starts? Most likely a valve seal.
Black smoke? Fuel.
IBA #11656
hutchman is offline
post #3 of 8 Old 12-24-2005, 10:54 AM
BBurton "BigB"
I don't think you are seeing smoke.... you probably are seeing moisture/steam. My bike does the same thing in cold weather start ups! It always goes away in about 2 minutes. You see the same exact thing happen with cars in colder weather. :wink:
post #4 of 8 Old 12-24-2005, 01:33 PM
Warren's Avatar
Ditto; I read this in a FAQ somewhere... Completely normal on startup when cool out.
[B]-- Warren in San Diego --
-- 2013 KLR 650 --[/B]
-- [URL="http://www.klr650.net/forums/showthread.php?t=47348"][COLOR=blue]Click Here For My Free KLR Valve Adjustment Shim Calculator[/COLOR][/URL][COLOR=blue] [/COLOR] --
-- [URL="http://www.vstrom.info/Smf/index.php/topic,10863.0.html"][COLOR=blue]Click Here For My Free V-Strom Valve Adjustment Shim Calculator[/COLOR][/URL][COLOR=blue] [/COLOR] --
Warren is offline
post #5 of 8 Old 12-24-2005, 02:03 PM Thread Starter
Yes, the smoke does quickly go and could well be moisture. Couldn't work out why only one side had moisture?
Simbad is offline
post #6 of 8 Old 12-25-2005, 08:51 AM
The moisture that comes out just one side has to do with the HPFM (hocus pocus [email protected]%$*!n magic) Mine does the same thing. Why just one side? - Donít know. I think it might be related to the laws of thermos bottles. You know, hot things hot & cold things cold. I keep two cups of coffee and a popsicle in mine. :roll:
Ron
If it's on sale, it probably should be.
R Hals is offline
post #7 of 8 Old 12-25-2005, 01:00 PM Thread Starter
eh? :shock: like to know what else is in your thermos :wink:
Simbad is offline
post #8 of 8 Old 12-26-2005, 11:34 PM
Re: Smokey exhuast - one side only
the smoke you are seeing is not smoke it is moisture or steam that goes away in a few minutes when your exhaust system heats up. take a look under your bike. there is a real bias to the left side of your exhaust system plus if your bike rests on a side stand then most of the moisture or condensation settles to the left exhaust. totaly normal, don't worry about it.
hope this helps.
kaos....
Kaptain_Kaos is offline
