Tightening sequence - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 2 Old 12-22-2005, 02:53 AM Thread Starter
Tightening sequence
Since I had the front end apart what is the proper tightening sequence?
Torque the tubes then the crown nut and finally the front axle? Or crown nut first and work down?
Let's go!
05 DL1000
Mountaintime05 is offline
post #2 of 2 Old 12-22-2005, 04:59 PM
TheTwins's Avatar
Start with front wheel & front axle off
Insert fork tubes one at a time, at approximate finished height, and tighten lower clamp pinch bolts in sequence. Step up 5 NM at a time till they're tight.
Secure big nut on top triple clamp, leaving the upper fork tube pinch bolts loose. If this nut is too tight, the steering will bind; if it is too loose your bearings will rattle. Spend the extra time and make sure it's right.
Loosen lower clamp pinch bolts to adjust fork tube height. Adjust one tube at a time and leave the other tube tight while adjusting the first tube. Repeat for the second tube.
Retighten lower clamp pinch bolts, in sequence, one then the other etc. 5NM at a time.
Tighten upper clamp pinch bolts in sequence as stated above.
TheTwins is offline
