green fluid - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 3 Old 12-14-2005, 04:14 PM Thread Starter
green fluid
I took a look at my dl1000 k4 the other day, and found a half dollar size puddle of coolant under the left side of the engine. Then I took the lower fairing off, and found the leak. It looks to be the gasket between the outside cover and the engine casing. It’s leaking from where one of the screws is. I was tempted to tighten the screw, but since it is still under warranty ('04 purchased in 2/05), I am trailing it in for the service.
I am thinking hard about extending the warranty, although this doesn’t look all that bad. Doug.
blue 2004 1000
DCDL is offline
post #2 of 3 Old 12-14-2005, 06:17 PM
There have been many reports of leaks from the radiator hose at the water pump. And loose clamps. Seems that on some bikes the paint prevents a good seal.
I declined the extended warrantee. Had it on my last bike and never used it. I hope I won't regret it.
Let's go!
05 DL1000
Mountaintime05 is offline
post #3 of 3 Old 12-14-2005, 10:05 PM
It's coolant OK. My K4 litre bike had loose clamps after a few thousand miles. Just tightening them once was enough to keep all that glycol inside the motor. It's been fine ever since. Or as we might say in northern New England, "Evah since."
Ride well.
'06 DL-1000
'06 KLX 250S (more fun than people should be allowed to have)
'72 SL-350 K2 (bump start only)
'72 CL-350 (on injured reserve list at this time)
“I guess it's better to bend a valve in Missoula than to lose your mind in Bozeman.”
-Barb Egan
MWValley is offline
