ordering chain and sprockets - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 19 Old 12-05-2005, 04:11 PM Thread Starter
just came back from a 1500 mile trip over thanksgiving and my chain is all stretched, to adj. the tension have to have swingarm covering last etch mark to tighten chain. where do you get your chains and sprockets and any thoughts on brands or model #s? also is it hard to replace front and rear sprockets? bike is 03 1000 strom. 13K miles of which 5k are mine since i bought the bike. so dont know if orig equipment or not. thanks lots. bike does have a center stand. jet
'03 dl1000 yellow
oxford hot hands grips
mp3 with yes and cindy woolf
mpcycle shields
jet7271 is offline
post #2 of 19 Old 12-07-2005, 03:59 PM
STROMETTE's Avatar
Location: ON THE ROAD... (frequent stops in AZ-85338, TN-37205, CA-96150)
Wow, I can't believe no one has responded to you here. I've had my DL1k for less than a month so I may not be qualified to post an answer here. However, I can recommend Sprocket Specialist for ordering. Also, I'm a big fan of DID chains (btw, nothing but riveted!) and I run steel sprockets on all my bikes. I'm actually going to be changing the gearing on my DL shortly to have 6th gear be more useable. :P
[B]aka "AGirl" - 2[/B][B]005 DL1000[/B]... [URL="https://www.stromtrooper.com/forums/showthread.php?t=5409&highlight=farkles+stromette"]MY STROM[/URL][COLOR=deepskyblue][FONT=Arial Narrow][COLOR=black][FONT=Arial] ...56,318 miles in 1yr of ownership[/FONT] :mrgreen: (2006 total miles on 2 wheels = 65,411) 8) [/COLOR][/FONT][/COLOR]
[FONT=Book Antiqua]* [I][FONT=Franklin Gothic Medium]Helmet laws interfere with Natural Selection[/FONT][/I]...[/FONT][B][FONT=Arial Black][COLOR=red]ATGATT![/COLOR][/FONT][/B]
[B][SIZE=4][COLOR=orange][I]:arrow: Join my journey...[/I][/COLOR][/SIZE][/B][URL="http://www.seizethejourney.com"]CLICK HERE[/URL]
STROMETTE is offline
post #3 of 19 Old 12-07-2005, 04:12 PM
Suzuki OEM replacements are SunStar steel sprockets and DID chain, both of which are good quality. I ordered everything through Ronayers.com. You might also want to order the bend-over type lockwasher for the front sprocket while you're at it.
moto_potato is offline
post #4 of 19 Old 12-07-2005, 04:25 PM
Warren's Avatar
Take a good look at your sprockets; you can typically go through two chains before they need replacing.
You may only need the chain.
[B]-- Warren in San Diego --
-- 2013 KLR 650 --[/B]
-- [URL="http://www.klr650.net/forums/showthread.php?t=47348"][COLOR=blue]Click Here For My Free KLR Valve Adjustment Shim Calculator[/COLOR][/URL][COLOR=blue] [/COLOR] --
-- [URL="http://www.vstrom.info/Smf/index.php/topic,10863.0.html"][COLOR=blue]Click Here For My Free V-Strom Valve Adjustment Shim Calculator[/COLOR][/URL][COLOR=blue] [/COLOR] --
Warren is offline
post #5 of 19 Old 12-08-2005, 11:42 AM Thread Starter
thanx for the feedback folks. have steel sprockets and oring chain on order from local cycle shop. i had trouble muddling thru the myriad choices of chain types and spockets online so i let them look it up for me. i'll have more confidence next time. how difficult is replacing both sprockets? i also have haynes service manual on order. jet
'03 dl1000 yellow
mpcycle shields
jet7271 is offline
post #6 of 19 Old 12-08-2005, 12:16 PM
I've got an 03 1000 with 13K miles. The chain is showing little wear and I'm hoping to get up to 18K out of it.
I would like to change the gearing, thinking of going up on the rear sproket when I replace the chain.
03 DL1000
98 R1100RS
98 Ducati 900SSFE
02 Polaris 6X6 (Bucky)
BmwDuc is offline
post #7 of 19 Old 12-09-2005, 11:34 PM
BillJones270's Avatar
That's a good question - to anyone who has replaced the chain and both sprockets, is it doable for a shade-tree guy like me? I'm fairly capable -- I would tackle the valve adjust tb sync, tps adjustment myself. My last bike was shaft drive, and I don't have a chain breaker, whatever that is
BillJones270 is offline
post #8 of 19 Old 12-11-2005, 06:46 PM
Warren's Avatar
Not too difficult. If you don't have a chain breaker, you can use a grinder or similar to cut the chain.
Master rivet links are a little tougher to do than a snap link, and you'll need a chain riviter for that.
http://cgi.ebay.com/ebaymotors/Motor...spagenameZWD7V
Warren is offline
post #9 of 19 Old 12-12-2005, 12:35 AM
Cool, thanks for the link Warren! I'd still probably feel better about it if I saw one being done first
post #10 of 19 Old 12-15-2005, 09:06 PM
What sort of miles does everyone get out of there chains and sprokets, I only have 7800 miles on my DL 650 so shouldnt have to worry about it for a while but am curious what the aveverage life is and if different chain lube optionsmake much differance to chain life :?
Suzuki 1982 GSX e400, my first
Kwaka 1982 Z 750 terrible bike
Yamy 1980 XJ 650 great bike
Suzi 1980 GS 450 got me around
Suzi 2002 GS 500 a real let down
Suzi 2004 DL 650 now this is a bike
Aussie Stromer 1039 is offline
