Removing Heat Shields Advice Wanted - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 10-31-2005, 09:03 PM
mdube
I purchased a pre-owned 2005 V strom with some cosmetic imperfections on both exhause heat shields. Apparently, the previous owner attached some saddlebags that rubbed the aluminum finish and created some rather extensive dark scratches. Can anyone advise on how to remove the shields? I'm thinking of replacing them. And does anyone know where to find replacements? I heard Ron Ayers may be a good bet.
Thanks
post #2 of 6 Old 11-01-2005, 05:37 AM
repair maybe?
maybe you could try giving them a light sanding? that should clean off the marks
I go hard because I cam
Flage is offline
post #3 of 6 Old 11-01-2005, 05:42 AM
MATTMAN's Avatar
Put an add in the classifides, there are enough people who get aftermarket exhuast that finding a set shouldn't be too hard.
BTW,
Some people call them scars, not scratches. Scars a are cool.
650...Anything more than a handfull is wasted
MATTMAN is offline
post #4 of 6 Old 11-08-2005, 01:52 AM
cyclerama2000's Avatar
Re: Removing Heat Shields Advice Wanted
Thanks
Hmmm. Maybe the DL1000 is different than the 650, but I have always heard that the aluminum-looking exhaust heat shield on the 650 is actually a special heat-resistant plastic.
Either way I am impressed that I can ride the bike for hours, turn the engine off and immediately touch the heat shield without getting burned. Now that's progress!
2004 DL650 - Blue
Yes, a DL650 can definitely do a major smokey burnout!!
cyclerama2000 is offline
post #5 of 6 Old 11-09-2005, 07:12 PM
Mine IS plastic. On the inside it states PC+ABS.
2004 DL650 - Blue
post #6 of 6 Old 11-09-2005, 07:40 PM
Thanks
You might be better off looking for a used set that someone removed from a new bike. The new shields would be about $250 so this might be a better alternative.
RubberDown is offline
