Front fork disassembly question - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 13 Old 10-04-2005, 01:43 PM Thread Starter
subagon's Avatar
I’m replacing the stock fork springs with some Wilbers. I read the service manual and have one question.
How much compression is the fork spring under? Should I be worried about flying springs :shock: ?
Mike
Tampa, FL
DL650K5
subagon is offline
post #2 of 13 Old 10-04-2005, 05:26 PM
SpeedStar's Avatar
When you remove the caps, they will pop up a little. It is not that bad though. I had a second set of hands when we did mine. That will help when putting it back together. I have the same springs on mine. Nice improvement. BTW, I went with the recommended 7.5wt oil and 150mm airspace.
SpeedStar is offline
post #3 of 13 Old 10-04-2005, 11:24 PM Thread Starter
subagon's Avatar
Just finished replacing the springs and as you said there's very little "pop" went removing the fork cap. Also used 7.5 W oil and 150 mm of air space. Finished at 11 PM so I didn't get a chance to test ride it. Just pushing down on the forks while sitting in the saddle I can tell a BIG difference. The old springs really dived, not these.
Mike
Tampa, FL
DL650K5
subagon is offline
post #4 of 13 Old 10-05-2005, 11:35 AM
Where are you guys buying the Wilbers springs from? Are those a progressive or straight-rate spring? What weight spring?? Probably going to be a winter project for me. :lol:
RubberDown is offline
post #5 of 13 Old 10-05-2005, 12:44 PM Thread Starter
subagon's Avatar
I got mine here;
http://wilbersusa.com/
Here's the reply from them when I asked about fork springs for the 650;
thank you for your interest in the Wilbers products.
Yes, we can offer you progressive fork springs for the DL650.
The set is $ 123.00.
The rate is 6.5 / 9.5 Kg/cm
We recommend a 7.5 SEA oil with a 150 mm airspace.
It took me about 3 hours to change the springs. Part of that time was spent putting the kid to bed plus letting the fork oil settle for 30 minutes. Next time when I need to change the fork oil it should only take about 90 minutes. Overall not a bad job, if you have the right tools. Some of the tools you might not have in your toolbox are;
12mm hex socket (front axle, hard to find Craftsman doesn't make one)
24mm socket (for the fork caps)
Torque Wrench
You'll need to use the above sockets so you can use the torque wrench when you put things back together.
A few tips;
Loosen the fork cap before removing the fork. The clamping of the fork in the fork clamp will hold the fork so you can loosen the fork cap.
When putting the fork back in the clamps don’t put the fork in its final position. Stop about 6 inches short and tighten the lower fork clamp bolt temporally. This will hold the fork while you tighten the fork cap. Then loosen the lower fork clamps and put the fork in it final position. If you put the fork in its final position before tightening the fork cap you’ll find out as I did that you can’t get a socket on the fork cap because the handlebar is in the way.
Read this somewhere and it’s a great tip; take a spray bottle like this, http://science.howstuffworks.com/question673.htm, take the bottle off and mark the plastic tube 150mm from the bottom. Fill the fork with oil, work out the air, then fully compress the fork and remove the excess oil with the sprayer, using the mark on the plastic tube as your guide for the 150mm airspace. I pumped the oil into the spray bottle for latter use.
Good luck,
Mike
Tampa, FL
DL650K5
subagon is offline
post #6 of 13 Old 10-05-2005, 03:39 PM
Thanks Mike!!!
post #7 of 13 Old 10-06-2005, 09:45 AM
wingman's Avatar
I too plan on making this a Winter project and have what might me a dumb question. Do you need to remove the forks from the triple tree? I looked in the manual and it shows removing the springs as part of the entire fork disassembly.
Wingman
2001 GL1800 Blue
2005 DL650 Red
wingman is offline
post #8 of 13 Old 10-06-2005, 02:51 PM Thread Starter
subagon's Avatar
Wingman
Yes, the forks need to be removed so you can drain the fork oil. Sounds harder than it really is. Quick version;
Remove calipers.
Remove front wheel.
Remove front fender.
Remove forks.
Remove spring.
Drain oil.
Add new oil.
Insert new spring.
Put forks on.
Put on fender.
Put on wheel.
Put on calipers.
Read the manual for the details.
Mike
Tampa, FL
DL650K5
subagon is offline
post #9 of 13 Old 10-07-2005, 03:06 AM
asteriksi
I wanted to order wilbers for my 650-V here in Europe, and I checked what Wilbers website offers:
http://www.wilbers-products.net/shop...elf_suzuki.htm
And there are two options for 650-Vstroms front springs
1) wilbers 600 = progressiv, order nr. 600-308-00
price 99euros
2) promoto 500 = progressiv, order nr. 500-308-00
price 79euros
Which ones have you installed?
And any knowledge what is difference between those springs?
Any worth spending 20euros more on 600-version springs?
post #10 of 13 Old 10-07-2005, 10:44 AM
wingman's Avatar
Thats great, thx Mike!
What made you go with Wilbers instead of Progressive or Works? At 250lb I'm not what you would call tiny. I plan on riding the bike in Shenandoah 500 next year and trying to decide what would work best.
Wingman
2001 GL1800 Blue
2005 DL650 Red
wingman is offline
