ECU # Bits - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 12-18-2003, 11:27 AM Thread Starter
ECU # Bits
How mant bits does ECU have. Is it 16 or 32.
scooter is offline
post #2 of 4 Old 12-19-2003, 02:14 AM
Actually it's the CPU Central Processing Unit I'am wondering about. I don't think the VS has a ECU .
Scooter
post #3 of 4 Old 05-20-2004, 05:31 PM Thread Starter
No it's the ECM which has 16 Bits not like the more powerful Gixxer computers which are 32 Bit. ECM probably stands for Engine Control Management. Unit monitors engine rpm, throttle position, crankshaft position,coolant temp.,gear position, and intake pressure. Its digital and is designed to improve throttle response, combustion effeiciency and fuel economy. The Dual Throttle Bodies are a large part of the system.
Scooter
scooter is offline
post #4 of 4 Old 07-10-2004, 01:19 PM
AATECH
You are incorrect, starting in 2003 the ecu has a 32bit processor, which alows for SDS or Suzuki Data System. it also has greater processing speed.
AATECH
Spare bits after messing around. 074KU DL650 and DL650A - 2004 to 2011 9 02-08-2018 08:48 AM
Rubber bits on 2015 GleeX 42228 DL650A - 2012-2016 1 12-20-2015 04:20 PM
Happy Trail Racks, Soloboxes, DIY mounting bits blue72beetle V-Strom Modifications and Performance 1 11-30-2013 11:00 PM
