Hi,
there is noticeably something wrong with my Vee. The first time I noticed Vee doesn't want to be in higher rpms and also the behaivour is a bit vibrating and rough it was when I've replaced chain with both sprockets. Bought x-ring SunStar and since that time Vee goes like I brake with rear brake - it's lazy. I've checked fuel quality, changed air filter for pipercross, had throttle bodies synced, changed oil (motul ester with MA2 specs / ussual in Europe). Checked spark plugs and they look fine (iridium with 5k on it).
Before that issue occurs I bought Gipro Atre and it worked fine.
Any idea what else should I check or did this happen to anybody? Just need some clue. Thanks
