coolant leak - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 9 Old 12-12-2003, 12:09 AM
zippy
coolant leak
I can smell coolant but haven't been able to spot a leak yet . I've read posts about riders with small coolant leaks, can someone point out where the culprit might be before I reinvent the wheel. Thanks
post #2 of 9 Old 12-12-2003, 08:35 AM
rodan
Check all of the hose clamps on the water lines. They tend to vibrate loose, and coolant will seep out.
I have heard of a few folks having water pump leaks as well, but have not had that problem myself.
post #3 of 9 Old 12-12-2003, 04:05 PM
Flyingyogi
I could smell the antifreeze as well. After I checked, I found 2 places, 1 on the rightside where the hose comes from the radiator to the engine, the other on the left side above the throttle adjustment, you'll see a hose in there. After tighening both hose clamps it stopped.
post #4 of 9 Old 12-12-2003, 04:25 PM
Mine had the same leaks. Tightened all the clamps, checked everything over, still leaking. Went to the dealer, and they put in some of those "stop leak" pellets. I questioned the wisdom of that, but they claimed Suzuki recommends it.
post #5 of 9 Old 12-12-2003, 08:07 PM
paul
there's also a little seep hole by the water pump on the right side of the bike that leaks for the first few thousand miles of break-in. Other Vstromers have confirmed that this comes and goes after break-in. Mine did also...
post #6 of 9 Old 12-13-2003, 01:07 AM
Motornoggin
Mine is doing this too. I can smell it, even see residue, but cannot find where it is coming from. Resivior level keeps going down. Very annoying. It didn't do it before I had the clutch replaced, now it does. The dealer strapped it to the dyno and ran it for quite a while, but could not find any leaks either. D'OH! If it isn't one thing, it's another..
post #7 of 9 Old 12-14-2003, 08:38 PM
zippy
found it
Thanks for the input, I finally got off my duff and located the leak. It helped that a big old green drop was getting ready to launch from the seal above the motor.
post #8 of 9 Old 01-24-2004, 10:27 PM
Slow Joe
Coolant smell/leak,(I had it @ 7K miles : 2002 Frankenstrom)
Look on the LH side of the bike , between the cylinders, you'll see there is the theromstat housing and hoses, check the 10mm bolts on the housing and hose clamps STONE COLD, NOT when the bike is hot , and just SNUG everything up, using ONLY a 1/4 " drive tools/socket , do N O T overtighten them ( especially the bolts) . then watch it for a residual/leak. :roll:
post #9 of 9 Old 04-14-2004, 04:37 PM
Woofy
Just noticed a leak on my 2003 as well. Right between the cylinders next to the idle adjustment. Will tighten it up and if that doesn't fix it, it's off to the dealer for a fix. Thanks to everyone!
Need help with coolant leak DS-61-3 Maintenance, Tech and Products. 1 04-25-2017 05:15 AM
2004 1000 coolant leak waituntilthebeep V-Strom Service and Maintenance Questions and Discussions 0 02-22-2017 09:35 PM
Odd Coolant leak btadlock V-Strom Service and Maintenance Questions and Discussions 7 12-12-2016 05:47 PM
Brand New 2015 650 VStom coolant leak? 1VStromNC DL650A - 2012-2016 13 06-26-2016 10:16 PM
Coolant leak - how to fix? paul167 DL650 and DL650A - 2004 to 2011 7 04-17-2013 03:44 AM
