1000 owners - I really need your help! - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 43 Old 09-16-2005, 12:29 PM
Luke
I'm currently having a problem with my K3 1000, in as much as my total tank range is only 160 miles until empty (not showing empty, conking out at the roadside empty).
The dealer is saying that because Suzuki don't publish estimated tank ranges or mpg figures, there is nothing they can do and I have no recourse.
I don't feel this is acceptable.
What I am requesting, is that as many 1000 owners as possible post here with:
Bike model or year, miles until fuel indicator flashes, known tank range (if possible)
Then hopefully I can go back to them with this information and demonstrate to them that I have a problem.
Thanks in advance,
Luke
post #2 of 43 Old 09-16-2005, 01:16 PM
Adventure Boy®
sandiegoland's Avatar
Re: 1000 owners - I really need your help!
Here is my data on a DL650K4 and a DL1000K5.
http://www.thumbwave.com/dl650/DL650_fuel.xls
"Indicators" get flashy and annoying at somewhere just over 4 gallons down on both bikes. That leaves at least one and a half gallons left (effectively). That would probably mean the flashing starts on the DL1000 normally no later than 150 miles.
My practical range on the DL1000 would then be 165-180 miles, filling up then with at least a gallon in reserve in most cases.
sandiegoland is offline
post #3 of 43 Old 09-16-2005, 05:04 PM
I am getting about 150 - 170 till the last bar starts to flicker. It has been getting worse over time so I am going to check/do a TBS and clean the airfilter. My mileage seemed to go down some with the dealer remap to get rid of the 2500-3500 lean spot.
"Oak tree, you're in my way"
04 1K VStrom - Kappa rack and bags, Heated grips, CRG bar end mirrors, Parabellum Windcreen, Wilber's mono shock, Corbin Smuggler seat and pillion, Hyperlights stop & Turn.
72 CB750K2&3&4 - Not much stock left
Convert is offline
post #4 of 43 Old 09-17-2005, 12:48 AM
I have an '04 DL1000 and it's about the same as Sandiegoland posted with my typical daily riding. My bike currently has 16,500 miles. On a recent trip w/ about 350-mile days, I filled up at 201 at one stop and still had about a gallon left in the tank (assuming my gas receipt was accurate based on 5.8 tank capacity).
phlooburoo is offline
post #5 of 43 Old 09-17-2005, 07:14 AM
tank full
my 4 month old strom goes 340km till it gets to the 2.5litre warning if i take it easy
regards camo
I go hard because I cam
Flage is offline
post #6 of 43 Old 09-17-2005, 10:03 AM
Thanks in advance,
Luke
Luke,
I have an 04 DL1000. my fuel mileage is about 49mpg if i cruse at highway speeds. no playing joe road racer. i just did a trip with a large package straped to the seat sticking out on each side by about 10 inches and about 12 inches high and was crusing at around 75 to 85 miles per hr. and got 42.5 mpg.
i once went 239.5 miles without filling up and i had about .4 gallons left..
my fuel bar will start to flash when i have about 1.5gallons left and the center of the fuel bar will start flashing with around 1 gallon left.
hope this helps.
I THINK YOU NEED TO FIND A NEW DEALER......
kAOS
Kaptain_Kaos is offline
post #7 of 43 Old 09-17-2005, 10:04 AM
Luke
Thank you all, this is very useful. Keep those figures coming
post #8 of 43 Old 09-17-2005, 11:12 AM
'03 40k+ miles, and fuel bar flashes at 160-180 miles usually at 175 and takes just under 4 gallons of gas. Always seem to get ~45 mpg.
"Travel has no longer any charm for me. I have seen all the foreign countries I want to except heaven & hell & I have only a vague curiosity about one of those."
Twain
BradM is offline
post #9 of 43 Old 09-17-2005, 09:01 PM
DL1000-K3 I get 40+ mpg. The last tank was a calculated 42.5. I have a PowerCommander (highly recommended). It hasn't affected the gas mileage much that I can tell. I have had both better and worse mileage before I put the PCIII in than what I am getting now.
ejy712 is offline
post #10 of 43 Old 09-18-2005, 10:12 PM
I have a 2004 DL 1000 and the fuel light starts flashing after I have used 4.4 gallons. My lowest mileage on a full tank is 41 mpg and the highest mileage is 50 mpg so my total range, assuming my tank is really 5.8 gallons, is between 238 and 290 miles. I have gone 250 miles on a tank a couple of times.
MCRIDER007 is offline
