Pulling codes on 1000 Strom - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 2 Old 08-29-2005, 04:55 PM Thread Starter
Gentlemen,
I just got my factory service manual and it shows a factory part which looks like a jumper wire with a toggle switch on the end for tying into the wire harness to pull fault codes. Does anyone know if this part can be purchased at the dealer or something else can be built or used for this purpose? Thanks in advance.
gbritnell
gbritnell is offline
post #2 of 2 Old 09-03-2005, 08:35 AM
codes
Hi
you do not need to buy the factory part. any jumper wire will work. in fact you can use a paper clip. i made up a small jumper wire to do mine after using a paper clip a couple of times. BTW my tps setting was way off. it transfered to the top bar at 4,100. hope thi helps.
Kaos
Kaptain_Kaos is offline
