Chain making very odd noise. - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 3 Old 08-16-2005, 07:26 PM
daveb196
Preface : I just came back from a ~2900 mile trip, where for 1400 miles or so I was running on a -very- tight chain set by the dummies at the local shop and stupidly not checked by me before leaving.
Anyways - my chain is making some very odd half squeak/half scraping sound. I first started noticing it at low speeds as I start significant acceleration, but I can get it to happen eaily with the bike on the centerstand and slowly turning the rear wheel by hand.
I narrowed the sound down to a definite source : where the center of the chain rides on the raised little rubber ridge on the chain guide of the swingarm. The rollers of the chain spin a bit as they move over this ridge. It sounds every bit like poorly lubricated ball bearings in say, a set of rollerblade wheels.
The sound goes away temporarily (100-200) miles with a shot of lube on the chain.
So I'm wondering - is it possible the o-rings are shot and the chain is on it's way out? Maybe brought on by the excessive tightness during a large trip?
Thanks for any advice!
post #2 of 3 Old 08-16-2005, 08:08 PM
It's the rollers failing, o-rings may or may not be okay, on a tight chain there isn't too many places for it to stretch other than the rollers. I'd also be sure to check that the counter sprocket seal isn't toast or the c/s shaft isn't bent. A new chain should be installed.
"Travel has no longer any charm for me. I have seen all the foreign countries I want to except heaven & hell & I have only a vague curiosity about one of those."
Twain
BradM is offline
post #3 of 3 Old 08-16-2005, 08:18 PM
daveb196
Will do. Conveniently, this trip rolled me right up to the 7k maintenance checkup mark, so I'll be sure to inform the service guys.
