New clutch! - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 9 Old 11-16-2003, 09:32 PM
Motornoggin
New clutch!
Rode the 'Strom for the first time yesturday since the clutch basket was replaced. I can't believe the difference it made. Truly night and day. The service writer mentioned to me how bad the clutch basket looked and that it would have failed sometime soon. It only had a little over 5k miles and didn't vibrate all that bad untill that last few weeks. I highly recommend that anyone with the "chudder" to get their bikes fixed as soon as they can.
post #2 of 9 Old 11-23-2003, 02:21 AM
CDN_RN
Hey Motornoggin, good to see you in another forum. Any regrets on making the switch from Drifter to V-Strom? I have absolutely none!
Pete
post #3 of 9 Old 11-23-2003, 11:28 AM
Motornoggin
Good to see you here. There are times when I do miss the Drifter, but I really don't regret it. The 'Strom is better in every way for the type of riding I like to do. The only thing the Drifter did exceptionally well was to look good.
post #4 of 9 Old 11-24-2003, 02:13 PM
paul
Zen
I spent some time last weekend putting the new basket on (adding a power commander, TRE, cart synch and K&N air filter). My baby is humming again...it was hard to believe that the new basket would actually make a difference - so I chugged it up a hill at the dreaded 2500 to 3500 rpm range. It purred like a kitten...
post #5 of 9 Old 12-15-2003, 06:20 AM
Gisle
Hi Motornoggin,
Good to hear the machine is running fine. Did you have the vibrations and/or the idle knocking sound before the swap? I am close to 5k miles and now have the knocking sound at idle. I've read up on clutches, but can't find the term "basket" anywhere? Care to elaborate to an engine novice? Mine is an 03 by the way...
Thanks,
Gisle :-)
post #6 of 9 Old 12-15-2003, 03:14 PM
paul
In the manual it's called a "gear assembly" and the new assembly number is 21200-06811. The new basket made the idle knocking less apparent but the true test of whether you have a bad basket is the sound your engine makes when pulling between 2500 and 3500 rpms...
post #7 of 9 Old 12-15-2003, 10:55 PM
Motornoggin
Originally Posted by Gisle
Hi Motornoggin,
Thanks,
Gisle :-)
Yeah, I had the idle "hammer" , as well as the "chudder" at 3000-3500 rpm before the swap. The 'Strom has a multiple disc wet clutch. The discs/plates are housed inside a basket. The discs have teeth that interlock with the basket and between these discs are plates that have splines that interlock with the shaft in the center of the basket. The problem with the 'Strom clutch is that because of an engineering/assembly flaw, the teeth wear into the sides of the basket too much. The excess wear increases the vibration which in turn, increases the wear, a vicious circle. The new basket compensates for the vibration and keeps the teeth from wearing into the basket.
If your's is hammering/vibrating, I highly recommend you have it checked and repaired.
post #8 of 9 Old 12-16-2003, 12:35 AM
Gisle
Thanks for the input, I believe I have the chudder as well. I have had the vibrations from the get go, but contributed it to the nature of a twin, since I've ridden mostly inline 4's in the past. So it's smooth all the way after replacement hmm? I'll have to get it done asap then. Thanks again.
Gisle :-)
post #9 of 9 Old 02-02-2004, 12:15 AM
freediverGA
please tell me alittle more about the discription of this chudder and the 2500-3500rpm problems?
I'm getting my new bike in two weeks and want to know what I need to listen and feel for when I starting riding my new bike!
Laxson OUT
06 Wee Clutch Engagement Problem tetsuo69 DL650 and DL650A - 2004 to 2011 7 06-05-2015 11:04 AM
Need Clutch Help Strange Dog DL1000 from 2002-2012 12 03-25-2015 11:11 PM
I am sorry but, another frigging clutch question. carlrf DL1000 from 2002-2012 33 10-29-2014 10:01 AM
Extended clutch arm? SRTeric DL650 and DL650A - 2004 to 2011 1 09-02-2012 02:47 PM
Help, clutch won't disengage! mirage V-Strom Service and Maintenance Questions and Discussions 13 06-04-2008 10:22 PM
