Removing fairing and repalce air filter -- new added pics - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 12 Old 07-03-2005, 12:04 PM Thread Starter
I found instructions on how to remove the fairing and used them and added some pics. I donít know who the author is and I apologize to the author for plagiarizing his / her work. Once I was able to remove the fairing I was able to change the air filter.
Text of instruction
removed the whole front fairing as a complete assembly.
You have to remove:
1. the black L shaped piece on both sides.
2. the small plastic piece at the front of the tank.
3. 3 Allen screws on each side.
4. 2 12mm bolts that fasten the fairing bracket to the frame.
5. un-plug the large plug on the left inside of the fairing.
6. spread the side panels apart and pull the whole thing off.
It is much faster than pulling the side panels off and leaving the
headlights and gauges and everything. You have to reset the clock when you are done though.
The pic are to illustrate most of these instructions. There were some variations to step 5 of these instructions because my bike had been modified by the previous owner. I did not remove the fairing because I had additional wires that I didnít feel comfortable modifying at the time. So some of the wires you see in the pics you wonít have.
I also did step 5 before 4.
Steps 1,2 are not pictured
Step 3 remove bolts 1 Ė 4 on both sides. ( bolt 1 is part of step 2) Do not remove bolts 5 and 6
Step 5 ď un-plug the large plug on the left inside of the fairingĒ . I had three plus to un-plug. The two plugs pictured and a powerlet out let not shown. I donít know if the two plugs shown are OEM . I could not recognize them as illustrated in the Suzuki DL1000 service manual.
Another view of the plugs
Step 4 ď2 12mm bolts that fasten the fairing bracket to the frameĒ
These bolts are located below the handle bars and triple clamp inside the fairing.
Another view of frame bolts
Once the frame bolts are removed you should be able to remove the entire fairing.
I wasn't able to remove the fairing because of electrical wires installed by the previous owner. But I was able to let the fairing gently set on my front fender while I remove the tank.
View of frame bracket that holds the fairing once faring is removed.
Dl1000 service manual page 4-51 Fuel Tank removed.
At this point , remove the rear fuel tank mounting bolt. Lift the tank and support it on the fuel tank prop stay. Next remove the fuel pump lead wire coupler ( brown connector) . Next place a rag under the fuel feed hose (black connector) and disconnect the connector. Very little gas will came out of the hose. On the right side of the tank is a vent hose , remove this.
Next remove the front tank mounting bolt. Your ready to lift the tank off.
I lifted my tank out without much effort even though it was full of gas.
Tank removed
Next unscrew the 8 bolts from the air box and replace the air filter.
Old filter
Make sure if you replace the old filter with a new one that you remove the O ring from the old filter and install on the new filter
New filter
Once you do it the first time it seems simple. Next put it back together.
Next TB sync
All pics are located here http://wasabi.smugmug.com/gallery/632774/1/26925365[/img]
Wasabi is offline
post #2 of 12 Old 07-05-2005, 11:22 PM
StromTrooper.com Founder
Howboucha's Avatar
Howboucha is offline
post #3 of 12 Old 07-05-2005, 11:50 PM
tank removal
great pics and write up. but i am wondering why you are removing the fairing to remove the gas tank. was there another reason for removing the fairing? i have had my tank off the bike four times now and have not had to remove anything but the two black trim pieces on each side and the black plastic piece that covers up the front bolt on the tank. takes me less then 5 minutes to take the tank off. just curious why you went to so much trouble?
but man that's one hell of a good write up and pics. geezz, i can't even figure out how to post pics. :roll:
Kaos :?:
Kaptain_Kaos is offline
post #4 of 12 Old 07-05-2005, 11:58 PM
BBurton "BigB"
I scratched the living crap out of my fairing, putting my tank back on!! Boy was I pissed... :evil:
post #5 of 12 Old 07-07-2005, 12:06 AM
oh geeeezz, sorry to hear about scratching your fairing. i had my beautiful and sensative life partner....." i get points for talking like that" hold the two halves of the fairing apart so i could slide the tank back in. didn't take to much spreading of the cowling halves to get the tank back in.
Kaos :?
post #6 of 12 Old 07-07-2005, 09:44 AM
SpeedStar's Avatar
Very nice post! Thanks for the detailed description and photos.
SpeedStar is offline
post #7 of 12 Old 07-07-2005, 02:23 PM
Gilk51's Avatar
Bill, love the annotated tank and fairing!
Reminds me of your "analog GPS"! :roll:
good write-up & photos.
.......Chuck
blue '04 DL-650
dark cherry '07 FJR
AARP member!
Gilk51 is offline
post #8 of 12 Old 10-28-2005, 12:08 AM
sempervee's Avatar
*Great write up and pics!!
I think I'll try it your way next time!! Now If I can only find someone walk me thru my first Valve Adjustment life would be perfect!! LOL!!
sempervee is offline
post #9 of 12 Old 10-28-2005, 09:40 AM
Re: tank removal
Kaos :?:
The service manual actually tells you to remove the fairing to get the gas tank off. I got about halfway through removing the fairing and it felt like a lot of work so I checked the MOM section on cleaning the air filter. The MOM tells you to just take off the side panels and the back end of the top black cowling. This works but it can be a hassle trying to push the side fairings out of the way when the tank comes off.
Wasabi's method of getting the fairing out of the way looks easier than the suggested procedure in the service manual.
On the subject of TB synch, the service manual has you remove the airbox and all its connectors, then reinstall the tank, then hook up the various sensors to the airbox. I found that it was impossible to hook the sensors up unless the airbox was more or less in place under the tank. I finally figured out that you had to remove the airbox to easily get to the vacuum nipples on the TBs. Some people have come up with small extension tubes that make it easier to get a manometer hooked up without having to remove the airbox. Once this is done, it was very easy compared to synching the four carb bank on my ZR.
06 DL-650 - SilverBlue
05 DL-650 - red (RIP - watch your mirrors!)
TomG is offline
post #10 of 12 Old 10-28-2005, 08:34 PM
This is the bit with the plastic rivets (or whatever they are), yes? How in the hell do these come apart? I tried pushing from the back side, but they just bent.
Mike
DL1000K5 Black with extra black bits.
Fast Traveller is offline
