Engine vibration - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 8 Old 07-03-2005, 05:03 AM Thread Starter
Engine vibration
From about 3000- 4200 rpm I hear a vibration coming from the engine area. Is this the clutch chatter or is it normal for a "V"? It runs fine but sounds odd when rolling easily on the throttle in first through 3rd gear. If more aggressive, not as noticeable.
wgm114 is offline
post #2 of 8 Old 07-21-2005, 10:31 AM
ArizonaDesertRider's Avatar
Re: Engine vibration
I too am experiencing the same exact condition. I am riding an 03 1000 with 8K on the clock. I have heard about a clutch issue, but can not seem to pin down the characteristics that lead up to replacement time. I also have not figured out if all the 03's need the replacement or was this a random problem? I called my Suzy dealer & they do show a "Superceded clutch basket" for the 03, I bought this 03 used & it has 6K on the clock, I just assumed that the Slow power roll on vibration was normal for a V-twin, until I started reading about this clutch issue.
Has anyone been through this clutch "thing" with an 03-1K ???
03 DL 1000
03 ST 1300
IBA 16332
ArizonaDesertRider is offline
post #3 of 8 Old 07-22-2005, 12:59 AM
Seems to be the norm of the DL1000s.
rider1951 is offline
post #4 of 8 Old 07-22-2005, 09:29 AM
marndo
When mine does this its time for a TBS, which eliminates it completely.
post #5 of 8 Old 07-22-2005, 04:47 PM
Big Benner
What's a TBS?
post #6 of 8 Old 07-22-2005, 05:47 PM
daswulf
What's a TBS?
Turner Broadcasting Station
:roll:
(throttle body sync)
post #7 of 8 Old 07-23-2005, 11:04 AM
wardy
They all do this, keep the revs above 4000 it's not like a Harley or Ducati V twin. When I checked my Throttle Body Sinc it was miles out and made a huge difference to the smoothness when set correctly. Check this site and http://11109.rapidforum.com/ for loads of info.
post #8 of 8 Old 07-25-2011, 09:34 AM
Banned
See if it's the "Chudder" - Chatter + Shudder = Chudder is the name those in know gave it. Shows as an annoying vibration through the bike in the 3 to 4k rpm area in all gears as you accelerate. Typical is it's most concentrated at 3,400 rpm to 3,700 rpm and sometimes you can't even ride through this range on a light throttle without feeling it.
https://www.stromtrooper.com/group-bu...tml#post699631
svman
svman is offline
