DL650 Oil Consumption - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 44 Old 06-17-2005, 10:47 AM
shlike
My '04 DL650 has 4100 miles on the odometer. For the first 3000 miles, it didn't use any oil. In the last 1000 miles (app.) I have had to add app. 1/3 quart to keep it at the full mark. I use 10w40 per the owner's manual. I'm just curious as to what kind of oil consumption everyone is experiencing, and if mine is normal?
post #2 of 44 Old 06-17-2005, 11:03 AM
Bobb_Todd
Mine hasn't used a drop in 50k kilometrs. Are you sure there was enough in it and you checked the same way ?
I would tend to run it a little low rather than over fill it
post #3 of 44 Old 06-17-2005, 01:26 PM
I think mine is using a bit of oil, too. I haven't really done precise checks, though. I have noticed that the oil takes a looonnngg time to settle down into the crankcase once the engine is stopped. You might try waiting 10 minutes to double check.
06 DL-650 - SilverBlue
05 DL-650 - red (RIP - watch your mirrors!)
TomG is offline
post #4 of 44 Old 06-17-2005, 02:25 PM
Mine is at 3700 miles and has not used any oil. 1st change at 500 miles and next one coming up at 4000.
Dave
Blue DL650K5
DaveJ is offline
post #5 of 44 Old 06-18-2005, 03:26 AM
heikkil
16.000 km and not a drop added between the oil changes (* knock on wood *). At least older SV650s were quite sensitive for over-filling so I've kept the oil level in the middle of the marks.
post #6 of 44 Old 06-21-2005, 07:17 PM
cyclerama2000's Avatar
5500 miles and the oil level is still right-on.
2004 DL650 - Blue
Yes, a DL650 can definitely do a major smokey burnout!!
cyclerama2000 is offline
post #7 of 44 Old 06-21-2005, 08:11 PM
Compared To What?'s Avatar
My 6Fiddy has just under 11k miles and doesn't use a drop between changes.
Compared To What? is offline
post #8 of 44 Old 06-22-2005, 10:05 AM
TheTwins's Avatar
In my mind, this topic supports the "break it in hard" theory. Sounds like your rings might not be seated as good as mine :lol: :lol: I really beat the snot out of my bikes after about the first 50 miles. I consider 45 minutes enough time for "break - in" then it's fun time - on to getting those rings seated properly.
TheTwins is offline
post #9 of 44 Old 06-29-2005, 06:00 PM
Originally Posted by TheTwins
In my mind, this topic supports the "break it in hard" theory. I consider 45 minutes enough time for "break - in" then it's fun time - on to getting those rings seated properly.
Yeah, add me to the Motoman bandwagon.
11,000+ miles and beating the crap out of the engine and it loves it.
No oil usage.
Castrol GTX10-40 rocks.
2004 V-Strom 650
2002 GS500
2004 KLR250
2014 DRZ400
mike183 is offline
post #10 of 44 Old 07-12-2005, 12:44 PM
Noodle
No visible oil consumption for 7,500 miles. Fairly hard break-in and dumped my first oil after 100 mi. Ran Spectro Petrolium 10/40 up to 7,000 miles and switched to the Spectro Synthetic Blend 10/40. No oil burn and smooth shifting!
