Stripped axle threads - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 15 Old 05-24-2005, 11:21 PM Thread Starter
:x
What a pissy night. I was planning on doing a quick chain adjustment and lube tonight and it turned into an ordeal.
I got the chain where I wanted it and tightened the axle nut with a 1/2" socket wrench to just snug. I got out my torque wrench, set it at 72 ft./lbs., then started to torque the nut down. I was pushing on the tire a bit with my knee because the right side wanted to slip back a little as the nut was tightened. The nut was getting close to tight enough but the torque wrench never clicked. I torqued the nut another 1/2 turn or so then decided that something didn't feel right. I then tried to loosen the nut to check things out and it took a lot of effort to finally get the nut off.
I took the axle out and the outer 1/2 of the threads are rounded off. There is also some sort of imperfection about halfway down the threads that almost looks like a tiny weld bead. I'm guessing that the nut hit this stuff and couln't grab any more threads. In the process, the threads in the nut got tweaked and that's what rounded everything else off when I loosened it.
The bottom line is that I think the axle was bad and I just hadn't hit the bad spot until this chain adjustment. I've never had the axle nut completely off so there's no chance of cross threading. I'll call the dealer tomorrow and see if they'll replace the axle under warranty.
Has anyone else ever run into this sort of thing?
06 DL-650 - SilverBlue
05 DL-650 - red (RIP - watch your mirrors!)
TomG is offline
post #2 of 15 Old 05-25-2005, 10:07 PM Thread Starter
I took the axle in today and the guys at the shop thought it may have been cross threaded at the factory. They said that the DL's ship with the rear wheel assembled.
They will try to get Suzuki to cover it under warranty but couldn't gaurantee anything. The worst part is that the new axle won't be in until Monday so I guess I'll be doing lots of yard work this weekend. :?
TomG is offline
post #3 of 15 Old 05-25-2005, 10:20 PM
Compared To What?'s Avatar
Compared To What? is offline
post #4 of 15 Old 05-26-2005, 10:41 AM Thread Starter
It does suck. The weather is absolutely gorgeous right now.
Fortunately, this happened after I had returned from a fantasic 1400 mile ride through the Blue Ridge Mountains. It would have really blown to miss that trip while waiting for an axle.
TomG is offline
post #5 of 15 Old 05-30-2005, 10:09 PM
I hope the dealer does the right thing and backs this up for you.
Yes it does suck to have your ride down for maintenance. Count your blessings however. Good thing the axle nut just didn't lose its grip while you were rolled over into a hard corner at about 50, eh?
Good luck getting back on the road.
'06 DL-1000
'06 KLX 250S (more fun than people should be allowed to have)
'72 SL-350 K2 (bump start only)
'72 CL-350 (on injured reserve list at this time)
I guess it's better to bend a valve in Missoula than to lose your mind in Bozeman.
-Barb Egan
MWValley is offline
post #6 of 15 Old 06-02-2005, 01:32 PM Thread Starter
Things are looking up. Zook was kind enough to cover the new axle under warranty and I spent some quality time cleaning my swingarm and chain last night. I should be rolling again tomorrow. 8)
TomG is offline
post #7 of 15 Old 06-03-2005, 09:42 PM
Der Strom
Axle
Same thing happened to a buddy of mine. His dealer covered it under warranty as well. Sounds like a common factory defect for sure.
post #8 of 15 Old 06-06-2005, 01:53 PM Thread Starter
I was wondering about that. I have a pretty cheap torque wrench and I considered the possibility that I over-torqued the nut. After looking at the thread pitch, though, I think you could probably torque that sucker until the swingarm started to collapse.
Might be a good thing for everyone to check on the next chain adjustment.
TomG is offline
post #9 of 15 Old 10-16-2005, 01:28 PM
Roaming
Me too!
The exact same thing happened to me. I had been messing with my chain alot cause from day one I have not been able to keep that chain tight. But anyway so I am retightening the axle bolt and I notice that it stops moving freely and the torque wrench hasn't clicked. then I try to back the nut back off and i get it about half way then is seises on me. so I take it to the dealer and they were able to replace the striped axle and nut for me. but now with the new one its starting to do it again and so I'm affraid to touch that thing now. Oh and my chain is still loose.
hope it doesn't fall off!
post #10 of 15 Old 10-16-2005, 08:51 PM
Re: Me too!
Are you sure your torque wrench is calibrated properly? I can see this happening once, but twice??
RubberDown is offline
