charging problem - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 9 Old 05-20-2014, 08:52 PM Thread Starter
av8or's Avatar
Send a message via AIM to av8or Send a message via Yahoo to av8or
charging problem
ok, i've been pouring over threads in here
went to start bike this morning 'clickclickclickclick'
well poop
jump it off car, starts up just fine, disconnect jumpers and it starts running funny and dies, jump it again and check voltage 14v while hooked up to car.
disconnect car and it drops down to 11v and starts running poorly.
get battery charged up starts just fine but doesn't run so hot
didn't get that burnt electrical smell from oil hole like greywolf recommends to check for.
find service manual, and start checking out leads, the manual is slightly different from my 07dl1000, the connector i believe to be from stator is 3 black wires (not yellow like in manual) and the r/r doesn't' have a big connector in the side, it has all wires, one going to stator connector(black with 3 all black wires) and one to a different plug (white with all black, black white stripe, black red stripe)
so what i find is there is continuity between all three leads, and its open to ground (so stator isn't bad then?) checked it while running and all three leads are producing well over 75vac @5000rpm (one was around 100 another 90 something and third was similar as well)
so i'm guessing now that my r/r is bad?
or am i missing something else?
can't quite follow service manual at this point because it diverges from what i have on the bike
so i beseech you, brain trust, where do i go next?
[COLOR=Blue]'07 Suzuki DL1000 V-Strom[/COLOR]
av8or is offline
post #2 of 9 Old 05-20-2014, 08:54 PM
Clean and tighten the battery cables. The battery might be bad too.
post #3 of 9 Old 05-20-2014, 11:09 PM
Sounds like the battery is the first thing I would check. Charge it overnight and see what the voltage on it about an hour after you disconnect the charger. I am suspicious of a bad cell from the description. On the other hand, the A/C voltages sound a bit high also....
realshelby is offline
post #4 of 9 Old 05-20-2014, 11:54 PM Thread Starter
av8or's Avatar
cables are tight and clean near as i can tell from when i reinstalled the battery a month or so ago (it was on bat tender jr all winter)
would that cause the undervoltage at the battery terminals though if charging system was working?
av8or is offline
post #5 of 9 Old 05-21-2014, 12:05 AM
Dark Angel's Avatar
The battery can still go bad on a tender. They don't last forever even with the best care in the world.
If you can fully charge it and after an hour off the charger the voltage is still good it's worth looking further. If not you need to sort out the dud battery first.
Dark Angel is offline
post #6 of 9 Old 05-21-2014, 01:59 AM Thread Starter
av8or's Avatar
pulled the btj connector an hour ago, just checked battery, 12.5v
battery is just barely 2 years old
av8or is offline
post #7 of 9 Old 05-21-2014, 02:01 AM Thread Starter
av8or's Avatar
forgot to mention something earlier, when checking the standalone voltage (no jumper cables) while running, if i reved it up it would drop even more to less than 10v, back to idle it would come back to 11ish
av8or is offline
post #8 of 9 Old 05-21-2014, 02:22 AM
Dark Angel's Avatar
If I went out now and put a meter on my battery I wouldn't expect any better than that, but that doesn't mean yours isn't collapsing under load.
What happens if you substitute a known good battery? You could check this by disconnecting the bike battery and using your car battery (without the car running of course) and monitoring the voltage.
post #9 of 9 Old 05-21-2014, 02:45 AM Thread Starter
av8or's Avatar
i can give that and any other suggestions a whirl but will have to wait till next week, going out of town for work
av8or is offline
Tags
battery , charging , electrical , regulator , stator
