first service - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 10 Old 04-22-2005, 03:57 PM Thread Starter
first service
What do they do for the $98 at that 600 mile service? Do they check the valves? Can/will they adjust the injection? Thanx, Doug.
blue 2004 1000
DCDL is offline
post #2 of 10 Old 04-22-2005, 06:12 PM
If you have a owners manual it will tell you everything that should be done at the 600 mile service. No they don't check/adjust the valve clearance. I do all my own services. :twisted:
RubberDown is offline
post #3 of 10 Old 04-22-2005, 09:45 PM
Essentially they change the oil, the oil filter and check the torque on a bunch of fastners. The only ones that were loose on my 1000 were exhaust parts. Some of them were plenty loose too.
Ride well,
Jeff
'06 DL-1000
'06 KLX 250S (more fun than people should be allowed to have)
'72 SL-350 K2 (bump start only)
'72 CL-350 (on injured reserve list at this time)
I guess it's better to bend a valve in Missoula than to lose your mind in Bozeman.
-Barb Egan
MWValley is offline
post #4 of 10 Old 04-23-2005, 07:29 AM
CDN_RN
Labor rates for motorcycles shops are probably on a par with BMW/Mercedes dealers!
post #5 of 10 Old 04-23-2005, 10:06 AM
MNwilly
Just a glorified oil change, I don't think most shops check fasteners either. I check for loose parts on every bike I buy as soon as I get it home. The Strom was typical compared to the last few bikes I bought, a few loose bolts. The right side passenger peg and the belly pan/cowl.
post #6 of 10 Old 04-23-2005, 03:20 PM Thread Starter
thanx
Thanx Guys.
From the horses' mouth, the service guy said oil, and tighten all the bolts, especially the triple clamp and exaust bolts. I'm keeping my $100, and checking every thing my self. Thanx again. Doug.
blue 2004 1000
DCDL is offline
post #7 of 10 Old 07-06-2005, 11:22 AM
Oops - just posted the same question in the Wee forum.
Up here in Canada, they are saying that a valve adjustment *IS* required and are trying to hit me for $300-350 (around $250 -275 US).
What gives?
Blue DL650K5
lajaro is offline
post #8 of 10 Old 07-06-2005, 11:35 AM
No valve adjustment as far as I'm aware....I thought the first one of those was at 14500 miles?
Pete is offline
post #9 of 10 Old 07-06-2005, 11:42 AM Thread Starter
bolts
I also found many loose bolts. It was surprising. None that were loose enough to fall out though. If you skipping the first service, check every bolt visible. I am going to check 'em once-a-year.
blue 2004 1000
DCDL is offline
post #10 of 10 Old 07-06-2005, 11:48 AM
...continuing the thread in the other forum:
https://stromtrooper.com/forum/viewto...?p=15881#15881
Blue DL650K5
lajaro is offline
